  1. #12
    as Clive said
    wire N/C switches in series
    it should be the safer option as the machine will stop if a wire breaks
    as this is more likely than a two core cable being short circuited
    (although it could happen if a cable is crushed)
    the last diagram of post 11 is for 1 axis ,
    you will need three pairs of N/C switches for the 3 axis
    as mach 3 only homes 1 axis at a time you could connect all 6 switches in series and use just 1 input
    John
  1. Limit switch problem
    By ECCO in forum General Electronics
    Last Post: 25-12-2015, 11:28 AM
  2. Limit Switch wiring question
    Last Post: 03-06-2015, 02:11 PM
  3. One limit switch per axis
  4. Limit switch wiring question ...
    Last Post: 31-10-2010, 11:06 AM
  5. Limit switch's - best configuration?
    By HiltonSteve in forum General Electronics
    Last Post: 13-08-2009, 01:26 PM
