    now I have seen the photo of your micro switch
    I can see why you are confused
    on my diagram the N/C contact is shown as the centre terminal
    and on your switches the N/C terminal is at the opposite end to the common
Name:	micro switch wiring.jpg
    John
    PS
    I can not find any details of the board to tell if the unused GND
    terminal can be used as an additional Ground / common for your switches
Name:	spare GND .jpg
    you will have to check for continuiy with the switch common terminal
    or use an additional terminal block to connect all the common switch wires together to a single wire from the switch common terminal
Name:	limit switch connections.jpg
  1. Limit switch problem
    By ECCO in forum General Electronics
    Last Post: 25-12-2015, 11:28 AM
  2. Limit Switch wiring question
    Last Post: 03-06-2015, 02:11 PM
  3. One limit switch per axis
  4. Limit switch wiring question ...
    Last Post: 31-10-2010, 11:06 AM
  5. Limit switch's - best configuration?
    By HiltonSteve in forum General Electronics
    Last Post: 13-08-2009, 01:26 PM
