  1. #18
    assuming you have the USB motion controllers "plug in " installed so Mach3 works via the USB connection
    to add the probe you will need to go into mach 3 ports & pins
    and select input signals
Name:	mach3 inputs.jpg
    about halfway down you will find the probe
    john
  1. Limit switch problem
    By ECCO in forum General Electronics
    Last Post: 25-12-2015, 11:28 AM
  2. Limit Switch wiring question
    Last Post: 03-06-2015, 02:11 PM
  3. One limit switch per axis
  4. Limit switch wiring question ...
    Last Post: 31-10-2010, 11:06 AM
  5. Limit switch's - best configuration?
    By HiltonSteve in forum General Electronics
    Last Post: 13-08-2009, 01:26 PM
