    If you get it working that's great but for a laptop with Mach3 you will also need to change the machine type as Windows is set to be able to turn off all sorts of stuff to save power on laptop which can cause problems, often only after 5, 10 or 15 minutes of machine run time. That's why the Mach3 manual states that laptops are not recommended and are unsuported.
    Hey there magicniner you dont have to be nasty and by the way I do have desktop computer which will be using for cnc and yes its windows 7 pro..i just wanted to try the laptop I had thats all. and I asked for some settings help ect,Im a newbie in the cnc world so please try to use better words next time instead of insulting me ok and Im sure there will be someone nice enough that will want to help me with the some hard settings information that I need help with...
    ***And by the way magicniner don't write to me if your going to be polite at all.take care***:(
    There's nothing nasty there at all, you are being over-sensitive and paranoid!
    I didn't even mention your chosen screen name :D
    listen Im not over sensitive but the fact you wrote in such a way,thank you for your help!. Please dont write to my profile anymore.if you do I will report you ok...:****
    I've read this thread and in fairness I don't think Magicniner was saying anything untoward. It is true that Mach3 advises against using laptops as they can cause instability.That doesn't mean it will definitely fail, but it might.
    BTW, I use a laptop and USB with absolutely no problems, but then I am not using Mach3. I use Kflop with KmotionCNC.
    Edward
    Quote Originally Posted by Schematicsman View Post
    I have no access to write to your profile, has someone edited your profile?
    If so you should report it to admin immediately as administrative access is required to do that!
    Hi let's not get of on the wrong foot here .everything is all right
    With my profile ..now please in future try to be more polite,ok I just wanted to try on my laptop, so I can learn how to set Mach 3 up for my machine and see how it goes then I will be using that info to set my desktop with Mach3 so if you or Edward wanted to help please by all means but choose appropriate words when writing to Schematicsman ok and there is no harm in trying, just had the laptop laying around,so lets start from the beginning. Here's a snapshot of my laptop showing diagnostics tab in mach3 now can you tell me if that looks goodClick image for larger version.
ID:	22957 ***Sorry for the pic being side ways took a photo with my phone? then I would like to get help with what I was asking at the start of my post, top of page......?????
    Photo rotated with Windows viewer.
    I am afraid that you will not get answers with an attitude like this. The only question I see in the above is you asking if the screen shot looks good and then you expect people to re read your posts to find out what and where the problem is without you bothering to find the post No. yourself.
    I did send you some links to vids and the manual for Mach3 but you don't appear to want to help yourself.
    I suggest that you read your thread from the beginning again and reevaluate what you have said.
    A quick Google Search with the board name yields this -
  1. Limit switch problem
    By ECCO in forum General Electronics
    Last Post: 25-12-2015, 11:28 AM
  2. Limit Switch wiring question
    Last Post: 03-06-2015, 02:11 PM
  3. One limit switch per axis
  4. Limit switch wiring question ...
    Last Post: 31-10-2010, 11:06 AM
  5. Limit switch's - best configuration?
    By HiltonSteve in forum General Electronics
    Last Post: 13-08-2009, 01:26 PM
