02-10-2017 #14but your drawing has com and NO pin connected and mine is NC and COM pin on mini limit switches...
check my pic of 2 switches for one axis in series connected and tell me if I have wired it correctly???Click image for larger version.
With a multi meter is is very easy to check you have it OK. You can also check if the two grounds ie the 5V one and the one you referred to are indeed connected together. If you are not sure use the 5v ground..Clive
Limit switch problem
By ECCO in forum General ElectronicsReplies: 7Last Post: 25-12-2015, 11:28 AM -
Limit Switch wiring question
By Boyan Silyavski in forum General ElectronicsReplies: 6Last Post: 03-06-2015, 02:11 PM -
One limit switch per axis
By EddyCurrent in forum General ElectronicsReplies: 17Last Post: 30-09-2013, 11:38 AM -
Limit switch wiring question ...
By Wobblybootie in forum General ElectronicsReplies: 20Last Post: 31-10-2010, 11:06 AM -
Limit switch's - best configuration?
By HiltonSteve in forum General ElectronicsReplies: 16Last Post: 13-08-2009, 01:26 PM
