hi i have managed to upload my cnc6040Z XML settings file that came with the cd for my machine.great i hope you can help me with everything from start to milling something.
i have also attached a pic of the actual limit switches i would like wire in series 2 per axis on the actual board....
<<<Now i know that 2 limit switches will have 2 wires coming from them ---->1) Com(black wire GND) /// 2) NC(Red wire)
so that is 6 wires /6 limit switches...>>>
now how and where on my jp-3163B v3.9 board i have attached a pic of , will 3 black wires and the 3 red wires be plugged in exactly ???
Also do i have use resisters with my limit switches or not i need full explanation i hope not ?????/??
Sorry for my persistence and rambling. :)Last edited by Schematicsman; 23-09-2017 at 05:32 AM.
23-09-2017 #2
23-09-2017 #3
I see Eddycurrent beet me to it
while I was adding to one of your pictures
with only the link to select either the internal +5v or an external positive suppy for the input opto isolators
but no link to break the ground connection
it looks like you can not take full advantage of the input
opto-isolators
as soon as I can I will down load mach3 to see what the XML file setting are
JohnLast edited by john swift; 23-09-2017 at 09:28 PM.
28-09-2017 #4
Hi,there john hows things,have managed to figure out how to wire up my board, I'm stuck cant get to use my machine I need help on how to wire up 2 limits per axis for my board in the most simplest way and also do i need resisters and what value . basically I need a complete instruction on wiring limit switches on the board specified above???? then exact Mach 3 XML setup to get my machine moving quick and start pcb isolation milling and aluminum milling,Please HeLP ASAP its frustrating me the whole thing is catching dust....
28-09-2017 #5
You have the user name "Schematicsman", you are going to mill a pcb, and yet you can't wire two switches in series ? plus you can't read the previous two posts ! having a laugh ?
28-09-2017 #6
01-10-2017 #7
29-09-2017 #8
hi there John for starters that is just a user name i came up with, has nothing to do with anything and im a newbie in all of this wiring and cnc stuff.so im trying to learn how to wire everything up and properly setup Mach 3 like everybody else to start doing some milling ect.and I need to know,do i need to use resisters and also how do I wire all coms together and fit the wires in the connector???? :(
29-09-2017 #9
Hi Schematicsman
if you have the jumper J1 set for using the boards +5V supply
you don't need to add any resistors - that's why I removed them from the original diagram
as to how you physically wire the switches it depends on what connectors you have fitted to the control box
very often you find "aviation" connectors are used on Chinese control boxes
the boxes having a number of holes for 4 limit switches and a probe
blanked off by a paper label when the connectors have not been installed
a photo of your box will help
if you fit four 2 pin connectors
then one pin on each connector is connected to the common ground
then printer port pins 10 ,11, 12, 13 can be connected to the remaining connector terminals
pin 15 can go to your E-stop switch
I will add more later when I return home
John
PS
this is the typical connectors found on Chinese control boxes
note – the danger of mains voltage on chassis mounting plugs !!!
from other posts
some other DIY options that have been used are
either pass the limit switch cable through a strain relief or
used a terminal block fastened to the box
once I know what you have and what method you want to use
either wire the limit switches directly to the breakout board or go via connectors mounted on the box
I will add more diagrams of the wiring
PPS
05-10-2017 #10You think that's too expensive? You're not a Model Engineer are you? :D
Limit switch problem
By ECCO in forum General ElectronicsReplies: 7Last Post: 25-12-2015, 11:28 AM -
Limit Switch wiring question
By Boyan Silyavski in forum General ElectronicsReplies: 6Last Post: 03-06-2015, 02:11 PM -
One limit switch per axis
By EddyCurrent in forum General ElectronicsReplies: 17Last Post: 30-09-2013, 11:38 AM -
Limit switch wiring question ...
By Wobblybootie in forum General ElectronicsReplies: 20Last Post: 31-10-2010, 11:06 AM -
Limit switch's - best configuration?
By HiltonSteve in forum General ElectronicsReplies: 16Last Post: 13-08-2009, 01:26 PM
