  1. #6
    I see Eddycurrent beet me to it
    while I was adding to one of your pictures
Name:	limit switch connections.jpg
    with only the link to select either the internal +5v or an external positive suppy for the input opto isolators
    but no link to break the ground connection
    it looks like you can not take full advantage of the input
    opto-isolators
    as soon as I can I will down load mach3 to see what the XML file setting are
    John
  1. Limit switch problem
    By ECCO in forum General Electronics
    Last Post: 25-12-2015, 11:28 AM
  2. Limit Switch wiring question
    Last Post: 03-06-2015, 02:11 PM
  3. One limit switch per axis
  4. Limit switch wiring question ...
    Last Post: 31-10-2010, 11:06 AM
  5. Limit switch's - best configuration?
    By HiltonSteve in forum General Electronics
    Last Post: 13-08-2009, 01:26 PM
