  1. #13
    Hi there John but your drawing has com and NO pin connected and mine is NC and COM pin on mini limit switches...
    check my pic of 2 switches for one axis in series connected and tell me if I have wired it correctly???Click image for larger version.
    Then which one of the COM or NC(NO) is GND or +5V and which one signal???
    also Can I use all ground connections from that free connector on the right side of the board near 24V that says::--->> C NO 0-10V GND-<<<---?????
ID:	22906 on this pic??????
    I'm confused
  1. Limit switch problem
    By ECCO in forum General Electronics
    Last Post: 25-12-2015, 11:28 AM
  2. Limit Switch wiring question
    Last Post: 03-06-2015, 02:11 PM
  3. One limit switch per axis
  4. Limit switch wiring question ...
    Last Post: 31-10-2010, 11:06 AM
  5. Limit switch's - best configuration?
    By HiltonSteve in forum General Electronics
    Last Post: 13-08-2009, 01:26 PM
