So magicniner yes the cable is parallel to usb one end connected to JP board in black box and the other end usb to my laptop so how and where would I be able to download the cnc6040 xml plugin that is needed to get this machine working with Mach3????Please help because If I cant get it to work with my laptop usb connection, I doubt the desktop pc would even work with the same usb connection.
I tried connecting 2 limit switches in series Normally closed to the appropriate pins Clive mentioned and in the inputs tab and enabled X+ X- Y+ Y- and green ticks on Active Low and there was no response on the diagnostics page I even tried Automated setup of inputs and no response ever.So I dont know what to do nothing seems to want to work.But thank you and everyone for all their help.i continue to read the manual And hoping to get some function if I can:)
My laptop is a ::::
Dell D620 2Ghz processor
With serial db9 connection and no DB25 parallel connection ....on the back if that helpsLast edited by Schematicsman; 05-10-2017 at 01:16 PM.
05-10-2017 #2
Are we there yet ?
05-10-2017 #3
06-10-2017 #4
hi,there magicniner can I just buy a cheap ebay Parallel Port PCIe x1 Card. and a parallel male to female or vice versa cable connected from JP board card to desktop computer to get Mach 3 responding? also is it possible to compile a xml of my machine spec ect for Mach 3 to work? just trying get around anyway I can without the cost cause I got the machine for a Bday present and it cost a sht load of money. Yes my laptop can accept a docking station and found one on ebay it does have parallel port and other ports,so I might still have a chance :)
06-10-2017 #5
Maybe you can maybe you can't... Nobody can answer that question about parallel port. I know Dell laptops can be tricky and even docking stations need drivers for the available ports to work. If your docking station is a REAL docking station, not just a port replicator type, then you may be able to get it work but you most probably won't do it without some pain and a lot of swearing. You must also be familiar with the configuration of your laptop and docking station BIOS, as well as the OS you are having. Windows 7 32 bits is the last one supporting parallel port, so you can't use anything better than that. Personally I have once tried with an HP laptop with docking station and XP, but it didn't work at all. I also tried just for fun with a more modern, HP ProBook6470b and W7 Pro 32 bits and it didn't work, even though the docking station had parallel port and other software using the parallel port worked with it, so it couldn't have been the OS or the BIOS or the configuration of the PC.
Anyway, if you want to stick to that PC then try the PCI card. If you are lucky and find the right card and drivers then it will work. If it is not working you can but the docking station and test it. Personally I'd buy an old desktop and would run it from there.Last edited by A_Camera; 06-10-2017 at 09:26 AM.
06-10-2017 #6
Later versions of Windows bring nothing to the party for serious Productivity Users, just the usual Microsoft "Change For It's Own Sake" and whistles, bells and novelties for Kiddies, Gamers and Non-Technical users who can't find a file, a programme, or indeed their arse with both hands, so I would argue that nothing later is better than that. :D
06-10-2017 #7
06-10-2017 #8
Some cheap Parallel Port cards will work well and some won't, you may have to try a few before finding one which works reliably, I haven't had to start testing the ones I've collected yet and may yet move to an integrated stand alone controller before I need to add a parallel to a PC that shipped without one.
It's worth starting a new thread to ask if anyone has PP card recommendations, you'll get a lot of external and stand alone motion controller recommendations but you only need one good card recommendation to get you working, one of my best hopes (but untested so far) is a StarTech as in the past I have used their stuff successfully to get legacy hardware working on newer PCs in industrial applications.
Forget about XML files, all they are is a way to copy and transfer an already completed manual configuration, it's simpler to manually configure unless someone with exactly the same setup can provide you a copy of their XML file.
Once you have your system working the config XML file which Mach 3 uses to store it's settings is one of the things you keep a backup of as this allows you to copy your setup to a new installation of Mach3.
Your laptop does look to be the right kind of age and a PP on a dock has a better chance of working than an integrated laptop PP (5v VS 3v), suck it and see is the only way to find out for certain unless someone else has successfully used the same hardware.You think that's too expensive? You're not a Model Engineer are you? :D
05-10-2017 #9
With a Parallel to USB you are on a hiding-to-nothing, no one is yanking your chain, they don't work because Art Fennerty's brilliant MACH3 Parallel Port driver cannot access the hardware through USB to read and drive the individual pins as it can on a local hardware bus Parallal Port
Plugins are bits of software which integrate with MACH3 to support hardware, XML files are configuration files containing MACH3 settings to work with a given machine configuration, ideally you would need both but in setting up MACH3 manually yo create your own configuration which MACH3 stores as a transferable (and copy-able and back-up-able) file.
You can't simply find and download a plug-in, plug-ins are not generic, they are hardware specific and must be developed and supplied by the hardware manufacturer, if they don't supply one you can't get one.
If your laptop BIOS shows parallel port settings you may be able to find a docking station with an external connector (this is the case with my HP Compaq machines although I don't use them as controllers), if so disable all power saving options for everything in BIOS while you're there before trying it.
The point of using older or Industrial market desktop PCs is that they have Parallel Ports and a Parallel Port is your only way forward with MACH3 unless you buy an external USB or Ethernet Motion Controller that does come from the manufacturer with a functional Plug-In - read around the subject well prior to purchase of USB or Ethernet motion controllers, suppliers are not above selling Lemons and shining customers on about Vapourware fixes and updates that never materialise.
John Stevenson has a shelf full of NBG controllers that were supposed to be the dog's b's if you listened to the sellers but were SNAFU and never adequately supported.You think that's too expensive? You're not a Model Engineer are you? :D
Limit switch problem
By ECCO in forum General ElectronicsReplies: 7Last Post: 25-12-2015, 11:28 AM -
Limit Switch wiring question
By Boyan Silyavski in forum General ElectronicsReplies: 6Last Post: 03-06-2015, 02:11 PM -
One limit switch per axis
By EddyCurrent in forum General ElectronicsReplies: 17Last Post: 30-09-2013, 11:38 AM -
Limit switch wiring question ...
By Wobblybootie in forum General ElectronicsReplies: 20Last Post: 31-10-2010, 11:06 AM -
Limit switch's - best configuration?
By HiltonSteve in forum General ElectronicsReplies: 16Last Post: 13-08-2009, 01:26 PM
