Hi I've had warco wm14 few months now and have decided iam going to covert mill but finding information is stuff warco dont have any kit for wm14 conversion but horizontal feed could easily done using arduino controler to give feed rates to servo motor and there is some available programs that with little tinkering would give adjustable feed rates like you adjust mill cutters speed and also give you micro adjustment ie if your couple of thousandth out just a case of adjusting code heres my email if you need to chat [email protected]
29-11-2020 #2
There are much easier and better ways to control the CNC side. LinuxCNC for instance is Free, all you need is a PC with a parallel port and a £5 breakout board and away you go with a super powerful Control software that is massively upgradeable. Arduino is a toy in comparison.
For less than £300 you can have a fully working CNC system comprising, PC, Steppers, drives, BOB, PSU-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
Converting a Warco Mill to CNC
By thorphar in forum Milling Machines, Builds & ConversionsReplies: 33Last Post: 11-03-2015, 09:58 PM -
NEW MEMBER: Hi from Lincoln
By centurian in forum New Member IntroductionsReplies: 0Last Post: 04-02-2015, 03:14 PM -
Cambium Code Web Tools – Parametric G-code Generation
By CambiumMachines in forum Manufacturer NewsReplies: 0Last Post: 09-01-2013, 04:56 AM -
NEW MEMBER: New member/machinist from Lincoln, East Midlands
By Franco in forum New Member IntroductionsReplies: 4Last Post: 01-08-2011, 12:03 AM -
NEW MEMBER: Greetings from Lincoln UK
By jesse in forum New Member IntroductionsReplies: 2Last Post: 30-09-2010, 04:50 PM
