Page 2 of 2 FirstFirst 12
    Lives in Marple Stockport, United Kingdom. Last Activity: 19 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Quote Originally Posted by Jeff View Post
    Thanks guys, really great insights.
    I guess that the lazy ass part of me thought that 48v was good because I could get away with an off the shelf PSU instead of building a 70v 12A linear :)
    Jeff here is the stock answer
    https://www.rapidonline.com/50a-brid...al-case-519318
    https://www.rapidonline.com/samwha-h...acitor-11-3121
    https://www.rapidonline.com/lcr-ep08...-clamp-11-3004
    https://www.rapidonline.com/single-primary?attributes={%22Secondary%20Voltage%22:[%222%20x%2024V%22],%22Power%22:[%22500VA%22]}
    the above is 500va but 625Va will give you a bit more upth.
  2. The Following 2 Users Say Thank You to Clive S For This Useful Post:
  3. #12
    Jeff's Avatar
    Lives in Filey, United Kingdom. Last Activity: 31-10-2017 Has been a member for 7-8 years. Has a total post count of 19. Received thanks 2 times, giving thanks to others 3 times.
    Thanks Clive, ordered the 25v-25v 625Va... Bigger is always better :)
  4. The Following User Says Thank You to Jeff For This Useful Post:
  5. #13
    I take it you ordered three caps
  7. #14
    Jeff's Avatar
    yeah, I realised it would be 3 x 4700uF in parallel, thanks again.
  8. The Following User Says Thank You to Jeff For This Useful Post:
  9. #15
    "Selecting Supply Voltage
    The power MOSFETS inside the AM882 can actually operate within +20 ~ +80VDC, including
    power input fluctuation and back EMF voltage generated by motor coils during motor shaft
    deceleration. Higher supply voltage can increase motor torque at higher speeds, thus helpful for
    avoiding losing steps. However, higher voltage may cause bigger motor vibration at lower speed, and
    it may also cause over-voltage protection or even drive damage. Therefore, it is suggested to choose
    only sufficiently high supply voltage for intended applications
    , and it is suggested to use power
    supplies with theoretical output voltage of +20 ~ +72VDC, leaving room for power fluctuation and
    back-EMF."
    from the AM882 manual obviously check your stepper driver specs first.
    Personally I went with 68v on advice from the forums the PSU build was very easy with Clive S help and I spent longer worrying about it than it took to build which was about 2 hours with 1 hour of pottering, smoking cig and drinking tea.
    Good luck with your build ;)
  10. #16
    I'm using the same motors, am882 drivers and a 68v psu. Got the motors running at 12500mm/min at first testing.
  1. Stepper and Drive sizing for Lathe Conversion
    By Robotwizard in forum Stepper & Servo Motors
    Last Post: 17-08-2016, 01:38 AM
  2. New Build Advise Ive Got Myself So Confused ! Please Help !
    By grain_r in forum Gantry/Router Machines & Building
    Last Post: 26-07-2014, 01:21 PM
  3. help sizing toroidal PSU to stepper/drives
    By paulus.v in forum General Electronics
    Last Post: 28-01-2014, 06:40 PM
  4. Confused need help!
    By manofgresley in forum CAD & CAM Software
    Last Post: 08-08-2012, 08:30 PM
  5. NEW MEMBER: New and confused!
    By nicodemus in forum New Member Introductions
    Last Post: 10-07-2011, 12:12 AM
