Thread: Confused about stepper sizing
Hi Jeff and welcome to the forum. In my opinion I would go with nema 23 3.1Nm from cnc4you and get AM882 drives from China and run them at 68V with a toroidal transformer power supply.
22-09-2017 #2
Hi Clive, I had looked at the motors from cnc4you before I confused myself with my calculations. I think I know where I stuffed it up I was getting confused about feed rates inches/m vs mm/m the speeds I used in my calculations are way too low. I'll do them again at around 10000mm/min and see where that leads me :)
22-09-2017 #3
Yeah that was where I was going wrong :). The 4Nm motors from cnc4you will give me cutting speeds of around 3000 mm/min and rapids around 10000 mm/min (which is as high as I can go due to the critical speed of the ballscrew), on a 48v supply with a 3x margin. 68V is way above the ideal voltage for these motors (3.0mH inductance) so I think I'll stick with 48V rather than turn my motors into workshop heaters :)
I'll probably get the CWD556 DSP drivers from there too.
22-09-2017 #4
22-09-2017 #5The "ideal" voltage is the voltage that makes them perform the way you need them to.68V is way above the ideal voltage for these motors
If you'll be cutting wood, you'll quickly find out that 3m/min is quite slow.Gerry
UCCNC 2022 Screenset
Mach3 2010 Screenset
22-09-2017 #6
I was basing the "ideal" voltage on the 32 x Square Root of inductance which, in the case of the cnc4you steppers would be 55v. The information on the Gecko website seems to infer that voltages above this "ideal" will just produce more heat through iron losses with negligeable torque gains. If you guys are using 68v without issue that would suggest the mathematical "ideal" and the real "idea" are not one and the same thing :)
22-09-2017 #7
It's more important to get the max current right and not worry too much about the voltage. The higher voltage gets the motor current up quicker on each pulse which helps keep the torque up. I'm running 3Nm motors on 68V with no problems, like a lot of people. I'm running 2 X axis motors, 3Nm, each driving 2005 ballscrews. I'm getting critical speed on the ballscrews, very similar size to yours, which is around 5m/min rapids. My gantry is probably heavier than yours as well. When you do the sums, don't forget the inertia of the ballscrew as well - when you get to this size, that value can be as much as the gantry.
Clive'a rule of thumb advice is on the money - do the sums, analyse as much as you like, and the answer's pretty well always 3Nm (4Nm), 68V! No point in going smaller (doesn't save much money anyway) and bigger gives worse performance.
Stepper and Drive sizing for Lathe Conversion
By Robotwizard in forum Stepper & Servo MotorsReplies: 0Last Post: 17-08-2016, 01:38 AM -
New Build Advise Ive Got Myself So Confused ! Please Help !
By grain_r in forum Gantry/Router Machines & BuildingReplies: 8Last Post: 26-07-2014, 01:21 PM -
help sizing toroidal PSU to stepper/drives
By paulus.v in forum General ElectronicsReplies: 13Last Post: 28-01-2014, 06:40 PM -
Confused need help!
By manofgresley in forum CAD & CAM SoftwareReplies: 12Last Post: 08-08-2012, 08:30 PM -
NEW MEMBER: New and confused!
By nicodemus in forum New Member IntroductionsReplies: 2Last Post: 10-07-2011, 12:12 AM
