27-09-2017 #7
Hello Wallace!
How do you plan to join the parts? Weld?
Welding can distort the frame alot..
If you want it to work without binding then you can use epoxy selflevelling or shim the rails. Shimming might be a big job with much trial and error :)
NEW MEMBER: Production grade CNC router Vs Homebuilt CNC router advice
By SweetAs in forum New Member IntroductionsReplies: 27Last Post: 16-02-2019, 12:06 PM -
Denford router - Brushed router too brushless spindle - Help and advice please
By Tom B in forum Brushless Spindles & MotorsReplies: 4Last Post: 16-05-2016, 09:13 AM -
BUILD LOG: my router build - advice needed
By thomashomer1986 in forum DIY Router Build LogsReplies: 10Last Post: 02-12-2013, 11:45 PM -
Looking to buy a ~4'x4' CNC router, advice welcomed
By Franco in forum Marketplace DiscussionReplies: 1Last Post: 02-06-2013, 10:05 PM -
Advice on which cnc router
By Xenophya in forum Milling Machines, Builds & ConversionsReplies: 0Last Post: 08-10-2012, 11:25 PM
