  1. #10
    Welded up the base and added legs.
    Milling ends to be square and even:
ID:	22898Click image for larger version.
    My Strong Hand jig. Very handy for getting things square:
    So, here's where I'm at now:
    Got these for X (Y?) axis. They are 35mm NSK and 756mm long:
    These things are beasts! Weigh about 25lbs. each.
    So, here are my next decisions. Any advice appreciated:
    - Putting another 2" square tube on top of existing ones for added stiffness. I can either mount rails on top (using epoxy to level), or mount rails to sides and use bolts for tubing to provide adjustment for parallelism. Leaning towards welding tube on and using epoxy...
    - Using only one of the trucks per rail. Given the size of these, would that work?
    All for now. Thanks!
    Wallace
    Going to add leveling feet today.
  2. The Following User Says Thank You to wallyblackburn For This Useful Post:
  1. NEW MEMBER: Production grade CNC router Vs Homebuilt CNC router advice
    By SweetAs in forum New Member Introductions
    Last Post: 16-02-2019, 12:06 PM
  2. Replies: 4
  3. BUILD LOG: my router build - advice needed
    By thomashomer1986 in forum DIY Router Build Logs
    Last Post: 02-12-2013, 11:45 PM
  4. Looking to buy a ~4'x4' CNC router, advice welcomed
    By Franco in forum Marketplace Discussion
    Last Post: 02-06-2013, 10:05 PM
  5. Advice on which cnc router
    By Xenophya in forum Milling Machines, Builds & Conversions
    Last Post: 08-10-2012, 11:25 PM
