    Lives in Marple Stockport, United Kingdom. Last Activity: 10 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,346. Received thanks 618 times, giving thanks to others 87 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    I will make the frame from aluminium extrusion of say 30mmx60mm long sides y-axis and 30mmx30mm X-axis. I'm thinking of using two 23nema Steppers on the y-axis unless this is overkill for the length. A 23nema on the X-axis and a 17nema on the Z-axis
    45x90 is a better size as the slots fit nicely with the BK and BF bearing etc. (assuming you are going with ball screws)
    nema 17 are not good enough for the Z with a 2.2kw spindle.
    1, Do CNC routers use similar electronics to a 3D Printer?
    2, Do the need microswitches for end stops?
    3, I see a lot of electronics in boxes with fans?? Do they produce that much heat?
    1. Yes but need more power suggest, using drives AM882 run at 68v
    2. its always a good idea to use limits and homing switches sensor type are cheap.
    3. It is usual to put a fan in the box to get the heat away
    It will be difficult to build on the budget you have stated I would estimate about £1500 to get a decent machine built by yourself.
    I take you have read through some of the build logs on here. Also its never a good idea to buy kits of electronics as they are never matched.
    You would be doing yourself a favour if you could draw the machine out in cad first.
  1. Wood cnc router for hobbyist
    By nerostjames in forum Machine Discussion
    Last Post: 01-01-2018, 09:28 PM
  2. NEW MEMBER: Hello! New hobbyist with ply furniture in mind
    By paulc in forum New Member Introductions
    Last Post: 17-06-2017, 05:23 PM
  3. Hot Foam cutter for RC aircraft
    By rckeith in forum Hotwire Cutting Machines
    Last Post: 10-08-2015, 08:32 AM
  4. Looking for local Laser Cutter to Leicestershire – Hobbyist Preferable
    By GoBo in forum Opportunities Available & Sought
    Last Post: 01-06-2015, 11:51 AM
  5. NEW MEMBER: Greetings from a hobbyist wannabe
    By Noplace in forum New Member Introductions
    Last Post: 14-01-2015, 04:25 PM
