    Quote Originally Posted by cambridge_cnc_stuart View Post
    Sorry I hadn't appreciated there was more than one version, everywhere I read it stated Mach3, so that was what I looked for.
    Does anyone know of some plans that I can follow and save making an expensive mistake
    Thank you
    Perhaps you can find some free of charge, but I think it may be difficult. Also, DIY means that you WILL make mistakes, so that should be added to the budget.
    Here is a link to a current build log:
    http://www.mycncuk.com/threads/11266-3-Axis-900x500mm
    The machine is about the same size you are planning for. Maybe he is ready to help you out, and maybe you can take a trip to him and have a look... Even if he is not in Cambridge, in your case I think it is worth to take a trip even if it might need a night in a hotel or B&B. He can definitely give you an idea about a realistic budget.
  2. The Following User Says Thank You to A_Camera For This Useful Post:
  3. #2
    Thank you A_Camera for taking the time to send me an in depth reply, it really is appreciated. I'm quickly believing I am out of my depth. Drowning in my innocence. I was quite confident to begin with, but that as now evaporated.
    Having spent many hours watching videos, reading builds, searching the Internet. I am now totally lost, confused and despondent.
    Back to the drawing board.
    Thank you once again
  4. The Following User Says Thank You to cambridge_cnc_stuart For This Useful Post:
  5. #3
    Clarification, all my 3D Printers have the option of printing from GCODE but I use them connected directly to a laptop or Desktop PC and can make changes on the fly. I have never used the SD card approach. The software I use if Simplify3d or Repetier Host.
    Respect
  6. The Following User Says Thank You to cambridge_cnc_stuart For This Useful Post:
  7. #4
    There is no need to spend more hours watching videos. Here on this forum 99% of the builds are exemplary plus the guys earlier have pointed you to all the details.
    Just to resume:
    nema23 3nm motors on all axis driven by AM822 at 70VDc
    1610 ball screws on all axis, 1605 on the Z, pulleys HDT5 15mm wide 20t from motor to ball screw
    2.2kw spindle is the typical compromise between power money and ability to cope with tasks
    20 size square rails Hiwin or chinese copy, don't use open builds or v rollers or skate rollers or other crap.
    buy all hardware from BST Automation Aliexpress or other reputable seller.
    Either use the recommended aluminum profile or make a structure from 80x80x3 or 100x100x3 box section.
    Just read the builds in forum, all is there detailed and with pictures. i don't know what is with all to imagine that they are engineers and design every single machine from scratch. Just copy a well known and successful build and spend your time using the machine, instead of designing it. if you are into welding use my first build as inspiration and there are free plans in Sketchup. If you are into aluminum even better, many good builds.
    You will need proper motion controller, not 3d printing solutions. Ethernet is what people use nowadays, not USB. CSMIO and Mach3, offline DDCSV1, UCCNC controller and software and so on.
    Also you will need a seriously big enclosure, Power supply ets.
    Once you start the build thread people will help you there so all will progress fast. But at the end of the day you will need to read some build logs,. Without that it will be too long to explain all. And dont read logs from the Zone as you will get too much useless information in your head.
  8. The Following User Says Thank You to Boyan Silyavski For This Useful Post:
  9. #5
    Lives in Marple Stockport, United Kingdom. Last Activity: 17 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,347. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Very good post Boyan Have a look a joe's log http://www.mycncuk.com/threads/4755-...-head%21%21%21 all done without special tools
  10. The Following User Says Thank You to Clive S For This Useful Post:
  11. #6
    Also some finished machines here:
    http://www.mycncuk.com/threads/10066...s-picture-menu
  1. Wood cnc router for hobbyist
    By nerostjames in forum Machine Discussion
    Last Post: 01-01-2018, 09:28 PM
  2. NEW MEMBER: Hello! New hobbyist with ply furniture in mind
    By paulc in forum New Member Introductions
    Last Post: 17-06-2017, 05:23 PM
  3. Hot Foam cutter for RC aircraft
    By rckeith in forum Hotwire Cutting Machines
    Last Post: 10-08-2015, 08:32 AM
  4. Looking for local Laser Cutter to Leicestershire – Hobbyist Preferable
    By GoBo in forum Opportunities Available & Sought
    Last Post: 01-06-2015, 11:51 AM
  5. NEW MEMBER: Greetings from a hobbyist wannabe
    By Noplace in forum New Member Introductions
    Last Post: 14-01-2015, 04:25 PM
