	03-04-2020 #1Hi Chaps,
 I can switch the spindle on and off in Mach4 no problem but when I close Mach4 the spindle turns on. I presume this is due to a setting in the smoothstepper. I have stop/start and feed hold state set to "force off". Also I double checked the BOB spindle relay is n/o.
 Also how do I configure the spindle to run in 0-10v mode? My BOB does not have a pin no for the 0-10v o/p how do I allocate it in ESS pins config?
 Finally does the BOB convert the PWM to anologue volts?
 BOB is generic "ECG Savebase"
 David
  Proximity switches or limit switchesBy chillybo in forum Gantry/Router Machines & BuildingReplies: 52Last Post: 29-06-2021, 11:50 AM
  Maplin closing-down saleBy Doddy in forum Classified Ads, Buy, Sell & SwapReplies: 0Last Post: 13-03-2018, 09:13 PM
  Mach4By D-man in forum Artsoft Mach (3 & 4)Replies: 3Last Post: 18-10-2014, 05:58 PM
  Mach4 in production run G52 offset with SubBy Lee Roberts in forum Artsoft Mach (3 & 4)Replies: 8Last Post: 25-08-2014, 11:53 PM
  Mach3 vs Mach4By Saracen in forum Artsoft Mach (3 & 4)Replies: 42Last Post: 15-09-2013, 04:55 PM
