Page 6 of 8 FirstFirst ... 45678 LastLast
  1. #51
    Lives in East Lothian, United Kingdom. Last Activity: 21 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    I'd try the setup as is. The worst case scenario is the belt flaps far too much and causes resonance problems, and you then have to add some idler pulleys.
    If it does need a couple idlers added, I would probably add a couple rollers to the top, to drop the belt down in the middle and increase wrap on the ballscrew pulleys.
  2. #52
    Rigged up a tensioner using stuff on hand - including a Subaru timing belt idler bearing:
  3. The Following User Says Thank You to wallyblackburn For This Useful Post:
  4. #53
    First movement!!!
  5. The Following 2 Users Say Thank You to wallyblackburn For This Useful Post:
  6. #54
    Lives in Marple Stockport, United Kingdom. Last Activity: 22 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    First movement!!!
    I don't think it will cut anything without a Z axis
  7. #55
    Quote Originally Posted by wallyblackburn View Post
    Be careful not to over tension because will deflect the ball screws causing whip when at opposite end of travel. It would have actually been ok without a tensioner thou it's better down out of the way.
  8. #56
    First movement!!!
    Thats not movement that's a twitch.!. . . . Let it have it's head to shake the gremlins out.
  9. #57
    Interesting. I’ll back off the spring pressure and adjust as needed when it’s actually working.
    Thanks!
  10. #58
    Thanks!
    Yes, that long run of belt, I would have probably around 10mm of easy deflection in it - you really do not want to "twang" timing belts like guitar strings ;)
    As long as they are not flapping in the breeze, the tension does not affect accuracy as much as you might think, but it will wear things out, cause resonance and generally not be good.
  11. #59
    What do you guys typically use for steps per revolution on your drivers?
    Thanks,
    Wallace
  12. #60
    Thanks,
    Wallace
    Totally dependant on the mechanical setup - pulley sizes etc
  1. "Hacking" and "Modding"
  2. Cnc router wood "roughing bits" anyone used these before?
    By gavztheouch in forum Motor Drivers & Controllers
    Last Post: 27-04-2014, 10:11 PM
  4. "Racks" VS "ball screw"
  5. BUILD LOG: Planning and build of my "8020" aluminium CNC Router
    By monza in forum DIY Router Build Logs
    Last Post: 06-02-2010, 11:55 PM
