    Hi everyone, I'm building my first machine and would appreciate some feedback on the following gantry design and whether you think it would work well as a design for cutting aluminium on a high sided cnc router.
    The gantry will be about 1000mm wide, 200mm high with a 200mm base. I would use either 10 or 5mm T6 aluminium for the triangular section.
    The reason I think it would be very stiff and resist twisting very well is because forces applied to the top edge would be transmitted down the angled panel to the linear carriages attached to the base. This would make back and forth and up and down movements of the top edge very difficult. The bottom panel would resist bending in the horizontal direction due to its depth and the vertical panel would resist bending in the vertical direction due to it's height. This combination would I think be very strong and also quite light as it only has three sides as opposed to the usual four, but I'd be interested in some opinions from experienced builders because I don't want to do something silly.
    Also, would 5mm plate be thick enough or is 10 better
    Thanks in advance
    fifa's Avatar
    Lives in bristol, United Kingdom. Last Activity: 26-11-2017 Has been a member for 8-9 years. Has a total post count of 31. Received thanks 3 times, giving thanks to others 0 times.
    The root cause of main deflection on gantry machine is twist of gantry itself. It must be very stiff... This is the reason why it is not usual design for metalworking machines.
    Think about mineral cast instead of beams. Weight-wise approx same, cost-wise probably same..., stiffness-wise much better, (also for Z beam)...
    regards
  1. Opinions on this router design
    By NB70 in forum Gantry/Router Machines & Building
    Last Post: 20-10-2017, 08:33 PM
  2. BUILD LOG: First Build-Steel Gantry CNC - Comments on design wanted
    By olaff in forum DIY Router Build Logs
    Last Post: 06-12-2015, 08:34 PM
  3. Opinions/Advice on my 800 x600 design
    By davegrennan in forum Gantry/Router Machines & Building
    Last Post: 10-07-2015, 12:03 AM
  4. Design ideas finally drawn up for your opinions please
    By Hopey in forum Gantry/Router Machines & Building
    Last Post: 25-03-2015, 10:10 PM
  5. Doosan CNC's? Opinions wanted!
    By Adtech in forum Milling Machines, Builds & Conversions
    Last Post: 30-09-2011, 02:08 PM
