Thread: Moving bed - bearing spacing?
So... after a bit of thought I'm going to revisit this idea, come up with a design, look at the advantages it gives me then put a cost on it and see how I feel about it.
I'm going to work around all the stuff I already have, as I have a full machine with 20mm profile rails, 1605 ballscrews, and try and come up with a better frame and gantry assembly to add rigidity.
I mapped out rebuilding the machine in its current format, just with using far beefier extrusions than the floppy thin things it's currently made of (the gantry beam is 20mm thick t-slot extrusion, 15mm gantry arms). I realised I'm going to lose work area anyway and like the idea of having a moving bed and the freedom to add all sorts of bracing to the gantry so I'm going to look at it properly.
I already have a solid 725 x 480 x 20mm bed made from aluminium tooling plate. The rails I have for it are 700mm long 20mm hiwin rails, and 4 HSR20A blocks. I don't know whether to bolt the rails directly to the bed or build a frame under the bed with the rails bolted under the bed frame. Bearing spacing is something I have no idea about. Should they sit at the edges in the width or maybe a third of the way in? Then in the length have a 150/200mm gap between the carriages which are 74mm long, giving a travel of 350/400mm. This is obviously where moving the gantry or the bed will be decided.
The other thing I have to decide before thinking more deeply about it and coming up with a plan is construction material. The tools I have at my disposal are
6x4 bandsaw
Angle grinder
Drill press
Nuts and bolts
Current CNC router
I can get a mate to do any welding but he reckons it will be difficult to get everything square and straight and will likely twist a bit during welding. How do you folks who have built steel frames manage to get everything properly square, and how do you manage to get a flat and coplanar surface to mount the rails on? General lack of experience working with steel is also going to make things more challenging. I can foresee costs escalating sharply and rapidly as I end up having to send stuff out for professional machining/correction.
Aluminium profile, whilst weaker and the base material more expensive, is easy, I have plenty of experience using it, I have my current machine that I can use to mill flat keys in for the linear rails. If I go with the fixed gantry I have the freedoms to belt and brace it to my hearts content. The cost would be purely material cost and any processing I can do by myself. I would probably go with heavy gauge 90x90 Bosch or 80x80 ITM profile.
The other option is just rebuild the current design using 80x80 and 25mm end plates/gantry arms etc which I priced up coming in at under a very reasonable £300 including fasteners and any extra tooling I would need (drill jigs).
The main goal is to get a better surface finish from cutting aluminium. Faster feeds and bigger cut engagement would be more of a (much welcome) added bonus.Last edited by Snapper; 13-10-2017 at 10:28 AM.
Help! Moving a big lathe...
By Jonathan in forum General DiscussionReplies: 21Last Post: 27-12-2015, 11:54 PM -
FOR SALE: Selling due to moving to Oz
By r0bsk1 in forum Items For SaleReplies: 7Last Post: 23-09-2014, 11:02 PM -
Bearing Spacing on Y-Gantry-Carriage
By WandrinAndy in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 29-10-2012, 01:16 AM -
BK12 Hole Spacing Dimensions On Top
By Hobgoblin in forum Lead Screws, Nuts & SupportsReplies: 2Last Post: 21-09-2012, 10:31 PM -
moving mach3 help please
By h4ppy-chris in forum Artsoft Mach (3 & 4)Replies: 12Last Post: 07-03-2011, 07:33 PM
