Thread: Spindle Orientation
17-10-2017 #1
Hi there, a machine at work has developed a fault, when the machine comes to change tools the spindle stops in the wrong position and the ATC crashes into the dogs of the spindle. I've had a look myself and used M19 to orientate the spindle and its wrong every time, Has anyone any ideas ? the machine is a Tryax BM600 running on Centroid M400 software. the machine has had no problems until now
Thanks in advance
Kev
17-10-2017 #2
Check the function of the spindle position sensor/encoder.
17-10-2017 #3
There is a round silver thing with wires coming out of it mounted directly on top of the spindle could that be it ?
18-10-2017 #4
It could be.
Does the spindle stop in exactly the same "wrong place" every time?You think that's too expensive? You're not a Model Engineer are you? :D
18-10-2017 #5
Yes it stops in the same place every time
18-10-2017 #6
Sounds like one of the encoder/sensor or the disc/component it senses, or the dogs have moved relative to the spindle.
If the thing you think may be the sensor is in fact the sensor and can be released, rotated and clamped in a new position then that may solve the issue.
Without determining the source of the problem and addressing it there is the chance of a recurrence.You think that's too expensive? You're not a Model Engineer are you? :D
18-10-2017 #7
Ok I’ve moved the encoder round in the slots and the spindle does now stop in a different position, not the right one though, but it does repeat with M19
18-10-2017 #8
Unfortunately I can't see it and know not to which slots you refer.
There's a possibility that the "Thing" which the encoder reads is what is out of place?
You're most of the way to solving the problem and becoming the Go To Guy for CNC repairs at work! ;-)You think that's too expensive? You're not a Model Engineer are you? :D
18-10-2017 #9
If you’re not too far away do you want to have a look at the machine and maybe fix it if you can ? Rugby
18-10-2017 #10
Kev,
I'd love to say yes but you're a bit far away and I work more than full time so unfortunately it would be difficult.
You know and have proven that it's a sensor/alignment issue, you ought to be able to get a competent technician in to sort that out fairly quickly,
Regards,
NickYou think that's too expensive? You're not a Model Engineer are you? :D
Chinese 300W DC spindle - is the spindle shaft grounded?
By HankMcSpank in forum Spindles & Drive MotorsReplies: 44Last Post: 26-11-2016, 07:25 PM -
Vcarve workpiece orientation
By D-man in forum VectricReplies: 37Last Post: 31-10-2014, 02:58 PM -
TB6560 controller Runs spindle on power up When Mach3 plunges spindle stops
By RoyT in forum Spindles & Drive MotorsReplies: 5Last Post: 29-09-2014, 02:42 PM -
CNC Spindle Repair and Spindle Replacement for any Machine of any Manufacturer
By spindeldoctor in forum Manufacturer NewsReplies: 0Last Post: 13-11-2013, 07:50 PM -
Spindle lock mechanism for 2.2kW china spindle
By Jonathan in forum Generic Chinese SpindlesReplies: 8Last Post: 13-08-2012, 08:39 PM
