You would be amazed at the capacity of a CNC machine to create a mess. If it is MDF based cutting then the fine dust gets EVERYWHERE. Metal is worse, as it is conductive and I have lost one motherboard this year from swarf ingress. Even with dust extraction some local filtration is a must. I would recommend one on your face to start with, then the PC should be in a case with filtered air being blown in. If you are running Mach3 and a parallel port, then a laptop is trouble because of timing issues and power saving.
I don't know about AutoCAD nowadays, but I run version R14, which is at least 20 years old, but does what I want. On a modern PC that can't be hogging too much in the way of resources.
19-11-2017 #2
If you get a small compact atom based system, say an Intel D525 (1M Cache, 1.80 GHz) based system, they don't really require additional cooling of the case they live in, filters on any intake fans/slots go along way still...
Coupled with proper machine isolation it should be a more or less non issue.
Link: Intel D525MW Intel Atom 1GB DDR3 RAM Mini ITX Bundle - £15.00
The 2.2Kw Chinese Spindles - Info, Setup and Advice + More
By Husky in forum Generic Chinese SpindlesReplies: 222Last Post: 22-01-2021, 06:54 PM -
MACH 3 requirements
By manofgresley in forum Artsoft Mach (3 & 4)Replies: 14Last Post: 08-01-2020, 07:22 PM -
Vacuum table Setup Advice
By andy_con in forum Machine DiscussionReplies: 69Last Post: 07-01-2016, 02:15 PM -
NEW MEMBER: Seeking advice on a CNC setup for (one off) machining carbon fiber plate
By Tomcat in forum New Member IntroductionsReplies: 0Last Post: 03-03-2013, 01:43 PM -
Strong 1212ds - any advice greatly appreciated!
By MrWiz73 in forum General DiscussionReplies: 14Last Post: 30-03-2011, 05:17 PM
