Page 2 of 2 FirstFirst 12
    I’ve just been on YouTube and there are some interesting vids on there that I probably need to study
    Lives in East Lothian, United Kingdom. Last Activity: 20 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    That info is incorrect. Macros run plenty fast enough, and in fact are used by thousands of people to auto zero there tools. The macro just calls the G31 move, and then retrieves the locations and sets the zero position.
    It is correct. Mach 3 macro refresh rate is 10Hz. If you need to detect an input pulse less than 100ms, then it cannot be guaranteed that a macro will detect the change, which is why you had to use PLC for many commercial tool changers.
    However, as I'm sure you're well aware, when you call G-code from a macro, that is then handled by the main motion engine, so is not restricted by the 10Hz refresh rate. The macro simply stalls until the motion is complete.
  1. WANTED: Coventry easy change tool holders
    By Benja in forum Items Wanted
    Last Post: 01-07-2017, 02:04 AM
  2. Ignoring tool change
    Last Post: 15-02-2014, 06:34 PM
  3. Mach3 Tool Change Position
    By Mad Professor in forum Artsoft Mach (3 & 4)
    Last Post: 15-07-2013, 06:54 PM
  4. XYZ Centurian 450 VMC tools sticking during tool change (M06)
    By craftydonkey in forum Milling Machines, Builds & Conversions
    Last Post: 19-10-2011, 03:11 PM
  5. WANTED: Tool holders for T2 (I think) quick change toolpost
    By Jonathan in forum Items Wanted
    Last Post: 07-05-2011, 10:30 AM
