    Lives in East Lothian, United Kingdom. Last Activity: 1 Hour Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,984. Received thanks 369 times, giving thanks to others 9 times.
    Dynomotion KFlop?
    Can pretty much program it to work however you want, and it'll work with Mach 3.
    If you're running drivers that accept differential inputs, I may still have enough parts around to create a step/dir differential driver board (or I could just do the SMD work, and you can deal with the through hole parts). Only drawback is with just a bare KFlop, interfacing to the low voltage signals can be a bit of pain (you can always add a Konnect to get 24V I/O).
    Only other options I can think of are Po-Keys, and the CNC-Drive controllers. PMDX also do some, but I think they're Mach 4 only.
    Jeff's Avatar
    Lives in Filey, United Kingdom. Last Activity: 31-10-2017 Has been a member for 7-8 years. Has a total post count of 19. Received thanks 2 times, giving thanks to others 3 times.
    I think Mesa / Linuxcnc is a step too far at the moment, I looked at Mesa/Pathpilot and discounted it for the same reason. I'd have bought the CSMIO IP/M in a heartbeat if it supported independent axis homing for slaves and I still haven't ruled it out completely but manually squaring the gantry seems like a bit of a fudge.
    The Purelogic board looks interesting but I can't find any English documentation, and I'm guessing support would be an issue too.
    The warp 9 ESS looks well supported but the cost with a PMDX-126 and shipping/import duty/vat puts this combo very close in price to the CSMIO IP/S so that puts me back where I started, either the CSMIO IP/M or a cheap standalone chinese all in one to get the machine moving and making chips.
    Lives in Plymouth, United Kingdom. Last Activity: 4 Hours Ago Has a total post count of 1,748. Received thanks 299 times, giving thanks to others 11 times.
    I went CSMIO because of its 24V operation, Ethernet, differential signaling, reputation for reliability. Cost wasn't that different to other options which all needed a decent BOB to be added. Manual squaring is a fudge, agreed, and I really think it should be in the IP/M firmware. But in practice, it's a trivial part of the startup process, so don't let that dissuade you too much.
  4. The Following User Says Thank You to Neale For This Useful Post:
  5. #4
    If you're not locked into Mach3, UCCNC with a UC300ETH and UB1 breakout board is an excellent alternative. Lots of 24V I/O, spindle speed control, analog inputs for feedrate and spindle overrides.
    And software that's actively being developed, that provides superior motion to Mach3.
    http://www.cncroom.com/interface-cards/uc300eth-ub1
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
  6. #5
    Gerry - does the UC300 support proper dual-motor axis squaring? If so, that's another big plus point.
  7. #6
    Jeff's Avatar
    I've watched some pretty impressive videos of the UC300ETH in action and it was definately on my radar, but that BOB you listed is seriously expensive. Would the UC300ETH run with an MB-2 which I know was designed for the ESS but appears to have all the functionality of the UB-1 for half the price?
  8. #7
    Quote Originally Posted by Jeff View Post
    $320 includes the UC300ETH. The UB1 itself is $180. Yes, you can use an MB2, but it would require a 5LPT motherboard for the UC300ETH, which adds $40, and makes it the same price.
    The UB1 + UC300ETH + UCCNC license = $380.
    An ESS + MB2 + Mach3 License = $565
    Also, the MB2 has less functionality then the UB1. The UB1 adds analog inputs, an extra analog output, and an extra relay.
    Gerry
  9. The Following User Says Thank You to Ger21 For This Useful Post:
  10. #8
    Yes, it does.
    Gerry
  11. #9
    Jeff, Purelogic do have English documentation. Ask them by their email address
  1. Advice on a charge controller please :)
    By blackburn mark in forum General Electronics
    Last Post: 04-05-2020, 07:28 PM
  2. Advice needed for controller box layout
    By Bustercnc in forum General Electronics
    Last Post: 18-01-2016, 01:16 PM
  3. USB/Ethernet controller for Mach3/4 advice
    By paulus.v in forum Control Hardware & Systems
    Last Post: 17-02-2015, 09:37 PM
  4. Advice please! JAF Motion Controller issues!
    By Mark Chard in forum Machine Control Software
    Last Post: 31-01-2014, 05:03 PM
  5. Which controller and motors? Newbie advice please
    By Nealieboyee in forum Motor Drivers & Controllers
    Last Post: 16-10-2012, 02:56 PM
