Page 2 of 2 FirstFirst 12
    I have the auto tool zero function working.
    Just struggling to set up the location, but that would all be fantastic.
    Thankyou.
    Lives in Plymouth, United Kingdom. Last Activity: 11 Hours Ago Has a total post count of 1,746. Received thanks 297 times, giving thanks to others 11 times.
    So, this doesn't do exactly what you need, but it might help a bit.
    toolchange macros.zip
    I suspect that what you need is something like:
    code "g53 g0 x[your tool change X] y[your tool change Y]"
    somewhere near the top of your tool height set macro. Note the G53 - this is important as it means "use coordinates on this line as machine, not work, coordinates"
    Can you post your tool height set macro?
    Hello Neale, I have sent you a email directly to you.
    Regards,
    Tim
    AUTO TOOL ZERO SCRIPT:-
    FeedCurrent = GetOemDRO(818) 'Get the current settings, OEM DROs (818)=Feedrate DRO
    ZCurrent = GetOemDro(802) 'OEM DROs (802)=Z DRO
    GageH = GetOEMDRO(1001) 'OEMDRO(1001)=Gage Block Height
    ZNew = ZCurrent - 300 'probe down 20 mm
    Code "G90F500" 'slow feed rate to 100 MM/MIN
    Rem Code "G4 P1" 'Pause 1 second to give time to position probe plate
    Code "G31 Z" &ZNew
    While IsMoving()
    Sleep(10)
    Wend
    Call SetDro (2,GageH) 'DRO(2)=Z DRO
    FinalMove = GageH + 10
    Code "G0 Z" &FinalMove
    Code "F" &FeedCurrent 'restore starting feed rate dr.lin 2009.10.16
  5. #15
    This thread can be closed now.
    All resolved thanks to Mr Neale.
    Thank you again for all your guidance.
    Tim
  6. #16
    Tim
  7. #17
    Hi
    I want to enable automatic tool change in Mach3 but I do not know how and where to start
    Can you help me?
  8. #18
    Personally, I would start with googling for "mach3 auto tool change macros"! That should give you some ideas.
    BUT - every machine is different, so needs different macros. Do you have a carousel or tool rack? Fixed or moving rack? Auto draw bar - how is it controlled? What are the locking mechanisms on a carousel? And that's just for starters. What motion controller are you using? How many inputs/outputs? Does it have PLC capability?
    This is non-trivial. Not necessarily difficult if you understand all the bits - mechanical, electronics, software - but a whole different ball game compared to the tool height setting macro that was the original topic.
    Good luck...
  1. Manual Tool Change
    By Kev2960 in forum General Discussion
    Last Post: 24-10-2017, 10:11 AM
  2. WANTED: Coventry easy change tool holders
    By Benja in forum Items Wanted
    Last Post: 01-07-2017, 02:04 AM
  3. Ignoring tool change
    Last Post: 15-02-2014, 06:34 PM
  4. Mach3 Tool Change Position
    By Mad Professor in forum Artsoft Mach (3 & 4)
    Last Post: 15-07-2013, 06:54 PM
  5. WANTED: Tool holders for T2 (I think) quick change toolpost
    By Jonathan in forum Items Wanted
    Last Post: 07-05-2011, 10:30 AM
