    The gcode you need is G28. This takes the machine to s predefined position, which could be your tool change position. You set the position (using machine coordinates) in one of the Mach3 configuration screens, although I can't remember which one off the top of my head. As m_c says, you can then incorporate this code into your M6start macro so that as part of the tool change operation, the machine will go to the tool change position. On my machine, I also have a fixed touch plate set into the bed at this point so I can do a "second operation" tool height setting without having to jog the tool again. When you hit "run" the M6end macro is called which by default takes the machine back to where it was when the m6 tool change started.
    I thought it was as easy as adding some more vbscript into my Auto Tool Zero script already? Would this work OR does it have to be done within the M6START & END Macro?
    Tim
    Lives in Plymouth, United Kingdom. Last Activity: 17 Hours Ago Has a total post count of 1,749. Received thanks 299 times, giving thanks to others 11 times.
    Can you explain exactly what you are trying to do? Everyone has their own way of working and I'm not quite sure what you're looking for.
    For example, my tool change code moves the tool to tool change position, waits until I hit Run, then goes back to where it started and carries on. While the tool is at the tool change position, I can choose to use one of the tool-height setting options I have written or not - they are not built-in to the tool-change macros themselves. That suits the way I work, but might not be right for everyone.
    Neale,
    When I'm running our GCODE to produce one of our units it had four cuts in total. I would like it to go to a certain position WHEN a tool change it needed then I press auto tool zero it hits my wireless probe (Which will be in a fixed location) zero's its self out and then returns to the next cutting position.
    Hope this makes sense to you! :D
    Tim
    Lives in East Lothian, United Kingdom. Last Activity: 6 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    Anything to do with toolchanges happens, or at least starts and ends in the M6 macros.
    I'm not entirely sure, but I think once you've used M6start to move to your toolchange position, you can then use your tool zero button, then once you're finished and click cycle start again, M6end takes care of moving back to the work area.
    Exactly. This is what I do on my own machine. All you need to do is put a move (in machine coordinates) to the touch plate location into the tool height set macro and the job's a good'un
  6. The Following User Says Thank You to Neale For This Useful Post:
  7. #6
    Neale could you copy and paste what's inside your M06.M1S file please?
    Regards,
    Tim
  8. #7
    Can do - will take a little time as I'll get the current copy off my machine. Might as well post m6start, m6end, and my tool-height setting routine while I'm at it. These all work, at least on my setup.
  1. Manual Tool Change
    By Kev2960 in forum General Discussion
    Last Post: 24-10-2017, 10:11 AM
  2. WANTED: Coventry easy change tool holders
    By Benja in forum Items Wanted
    Last Post: 01-07-2017, 02:04 AM
  3. Ignoring tool change
    Last Post: 15-02-2014, 06:34 PM
  4. Mach3 Tool Change Position
    By Mad Professor in forum Artsoft Mach (3 & 4)
    Last Post: 15-07-2013, 06:54 PM
  5. WANTED: Tool holders for T2 (I think) quick change toolpost
    By Jonathan in forum Items Wanted
    Last Post: 07-05-2011, 10:30 AM
