01-03-2025 #2
A birt late to reply to this. I had a similar problem, same machine.
I found the relay that controlled the spindle was a bit sticky. If you activate any of the safety switches a few times it might jolt the relay back into action. Also check the postiton of the delt on the spindle pulleys, I had an issue where I was asking the lathe to spin faster than the motor could with the belt position. This resulted in the spindle error. The spindle would attempt to get up to speed then fail as it couldn't go fast enough.
Hope that helps
Emco PC120 Turn
By Chaz in forum Emco LathesReplies: 140Last Post: 14-08-2017, 09:47 AM -
EMCO Concept mill error message
By kumar in forum Machine DiscussionReplies: 4Last Post: 03-06-2016, 02:59 AM -
CONVERSION: Emco F1-p Mill Mach3 convention, Spindle motor problem
By andre13442 in forum Conversion Build LogsReplies: 7Last Post: 14-01-2016, 12:14 PM -
Emco C5 spindle motor control
By GeoffV in forum Motor Drivers & ControllersReplies: 2Last Post: 19-03-2014, 04:20 PM -
EMCO Spindle Control
By Pete92 in forum Spindles & Drive MotorsReplies: 1Last Post: 06-11-2013, 10:20 PM
