Thread: Aluminium profile CNC
20-11-2017 #18
The extrusion is not too high all I wanted to point out was that using extrusion, especially thin wall (gauge) extrusion, will be the limiting factor for the stiffness. The wall is thin, and it essentially has lots of deep slots cut in it. Imagine pressing sideways where the gantry rail is situated, and imagine how it will want to bend and vibrate.
Lost of people use steel box section instead as it is much stiffer, with a continuous outer section, usually with a high wall thickness (to allow thread tapping), and it is cheaper.
End plates of 5mm will be fine as shear panels don't need to be massively thick to be effective, but it will limit feed in / out access if that is a consideration.
Hiwin carriages - either wide or narrow are both fine. Use wide if that gives a better footprint and mounting for your design.
Aluminium profile cnc build
By valdis034 in forum Gantry/Router Machines & BuildingReplies: 84Last Post: 21-02-2023, 02:27 PM -
Aluminium Profile - ValuFrame?
By Tenson in forum Marketplace DiscussionReplies: 12Last Post: 24-09-2020, 07:21 PM -
Aluminium Profile
By amxen in forum Metalwork DiscussionReplies: 2Last Post: 13-08-2015, 07:37 PM -
eBay: KB Aluminium Profile Supplies
By KB Aluminium in forum Items On eBay UKReplies: 45Last Post: 20-05-2015, 03:46 PM -
Tapping Aluminium profile
By jonbabbz in forum Tool & Tooling TechnologyReplies: 3Last Post: 28-05-2012, 08:09 AM
