Thread: Aluminium profile CNC
20-11-2017 #17
Yes it is, but, the ends are fixed - the weight/force now tries to act upon the whole beam but cannot move the ends as they are fixed - it will then act upon the point where the force is applied, if say it is applied centrally then the force will try and bend or push the beam in the opposite direction to the force - the beam will bend. The skill in designing beams is to transmit those forces to the ends of the beam without letting it bend - this is done by using heavy enough section material or bracing thinner section material with struts or triangular trusses.
Vibration is the same really, just many more, smaller forces that need dampening out or preventing in the first place - mass is a good way of stopping vibration or at least moving the harmonic point to somewhere outside the range of expected vibrations.
Aluminium profile cnc build
By valdis034 in forum Gantry/Router Machines & BuildingReplies: 84Last Post: 21-02-2023, 02:27 PM -
Aluminium Profile - ValuFrame?
By Tenson in forum Marketplace DiscussionReplies: 12Last Post: 24-09-2020, 07:21 PM -
Aluminium Profile
By amxen in forum Metalwork DiscussionReplies: 2Last Post: 13-08-2015, 07:37 PM -
eBay: KB Aluminium Profile Supplies
By KB Aluminium in forum Items On eBay UKReplies: 45Last Post: 20-05-2015, 03:46 PM -
Tapping Aluminium profile
By jonbabbz in forum Tool & Tooling TechnologyReplies: 3Last Post: 28-05-2012, 08:09 AM
Should I place the rails on top and bottom or is it fine?
