Page 6 of 8 FirstFirst ... 45678 LastLast
  1. #51
    Attachment doesn't open for me ?
  2. #52
    Me neither ;)
  3. #53
    Me neither ;)
    try again ;)
  4. #54
    Me neither ;)
    try again ;)
  5. #55
    Now I totally understand what you ment about loosing travel ;)
  6. #56
    Thanks for the photo. Mine is similar as you said (I will post upgrade soon), but the X ballscrew is on top of the axis.
    I plan to use 1605 screw for the Z axis with a 2.2kw spindle. The distance between X rails and spindle will be ~23cm.
    I think, with this configuration, it will have more leverage. Is it right?
    I will try to put X rails on top and bottom. Thanks for the advice ;)
  7. #57
    Is it a good idea to replace the light 40x120 profile with
    a heavy 40x160 or heavy 80x160? Z clearance will be around 150mm (5.9"). This way there will have only one plate on top of the bearing blocks to support the X axis.
ID:	23585   Click image for larger version.
  8. #58
    Looks much better ;)
  9. #59
    I just find time to update my design and change several thing. I hope I take into account every advice.
    If you see anything wrong please let me know. Thanks.
Name:	CNC v19 back.png
Name:	CNC v19 left.png
  10. #60
    my ballscrew isn't very straight. Could it be a problem when everything's bolted down?
    Is it a correct way to adjust the space between ballscrew and plate?
  1. Aluminium profile cnc build
    By valdis034 in forum Gantry/Router Machines & Building
    Last Post: 21-02-2023, 02:27 PM
  2. Aluminium Profile - ValuFrame?
    By Tenson in forum Marketplace Discussion
    Last Post: 24-09-2020, 07:21 PM
  3. Aluminium Profile
    By amxen in forum Metalwork Discussion
    Last Post: 13-08-2015, 07:37 PM
  4. eBay: KB Aluminium Profile Supplies
    By KB Aluminium in forum Items On eBay UK
    Last Post: 20-05-2015, 03:46 PM
  5. Tapping Aluminium profile
    By jonbabbz in forum Tool & Tooling Technology
    Last Post: 28-05-2012, 08:09 AM
