Thread: Help Please for Moving Gantry
28-10-2017 #1
Hii please help me to build My CNC milling machine.
I am not a fully machinist designer so I am getting confuse in building a CNC machine.
I was watching a lot from past 2 years, however coming to any poster they wouldn't provide full details in their threads.
Can somebody provide a open source of DIY Moving gantry for Metal milling.
I am making on the Table for 31 inches into 71 inches with 50 MM square pole, thickness of 5 or 6mm
This looking easier to build, but doesit can handle for milling metal?
http://www.mycncuk.com/threads/11358...-and-hardwoods
Mods, please move thread if this is not right section.Last edited by endlasuresh; 28-10-2017 at 12:29 PM.
29-10-2017 #2
Still no replies,
I had designed the base will post here tomorow and looking to buy rails offline. Can somebody recommend me the best rails for me?
29-10-2017 #3
Hello!
What metall do you want to mill? Steel?
50mm steel square for the base is to small I think.. I have 50mm for my planned mostly wood router (with some 80x120 6mm thickness in there ). It will never mill steel
... Also I have 6mm thickness I think..
Usually people recommend 80x80 with atleast 3mm thickness for router capable of routing aluminium.
For your rail question it depends on how the machine looks and how heavy it is.
Usually 20mm square linear rail is recommended. But it you plan on a monstermachine capable of milling 100mm thick steel it may be a different world altogether :)
Post your design an listen to advice before ordering parts. It might save you some money in the end
The Following User Says Thank You to Nr1madman For This Useful Post:
29-10-2017 #4
Most people would recommend a mill style machine for cutting steel as it is possible to build a much stiffer machine as the Z axis is grounded to the base. But there is a limit to the footprint fore aft that it can cut.
Then a gantry machine makes more sense as it can cut much larger pieces but to machine steel it needs to be well built.
The one you linked to looks like a fine general machine but it would not be recommend for steel. Everything needs to be much stiffer including using big profile linear rails not supported round rails etc
I can't remember seeing a gantry machine on this forum designed just for steel so you are not getting much direct advice.
29-10-2017 #5Hoe about Chaz's machine with the concrete gantryI can't remember seeing a gantry machine on this forum designed just for steel so you are not getting much direct advice...Clive
29-10-2017 #6
Hi Clive I meant moving gantry but yes I had forgotten about Chaz's machine which will cut steel.
Endlasuresh
Have a look in the build log at Chaz's machine to see how he approached it. I'm sure this is not what you had in mind but what you can take from this is just how stiff and heavy the machine needs to be for steel
31-10-2017 #7
Thanks for all replies, here is my answers for your questions.
@Nr1madman
1. The steel would be EN 8 to EN 31 plates.
2. Ill got with 100 mm Square poles with 5 or 6 mm thickness
3. Ill go with 20 or 30mm square rails as per your suggestion but will post design soon.
4. I made the design in simple base not fully, but thinking to go with Fixed Gantry.
@routercnc
I think you are saying mill style machine that I believe fixed gantry. CAn I got with Wade O Design?
Someone suggested for moving gantry in CNC zone forums few years back, but they never replied again and never made anything.
Yeah got it what you said yes I am too loking more stiffer than the one I linked, but the design is so easy to process.
I also checked Chaz design but looks it is a fixed gantry. http://www.mycncuk.com/threads/9616-...d-that-be-Zeus
Is this is the machine that you are talking about it?
Let me know whether I should go with Wade O design as it is easier to make and i will modify according to our need.
01-11-2017 #8
Here is the link a long back 7 years ago this guy recommended me for Moving Gantry, but till today I did nothing.
http://www.cnczone.com/forums/diy-cn...tml#post864638
The guy told moving gantry because for the wieghtage of milling plate. I am looking the easiest method to build it.
01-11-2017 #9
Hello again..
Just to make it more clear.
Do you want to mill or engrave steel?
01-11-2017 #10
For milling, mostly will be used for Plastic Molding Dies. Thanks again.
BUILD LOG: Build Log: 4'x4' Moving Gantry CNC Router
By GeorgeW21 in forum DIY Router Build LogsReplies: 14Last Post: 20-01-2019, 09:33 AM -
Beginner Moving Gantry Build? Read This!
By Tenson in forum Gantry/Router Machines & BuildingReplies: 3Last Post: 23-05-2018, 05:30 PM -
Now That's a Serious 4-Axis Moving Gantry Machine!
By magicniner in forum Machine DiscussionReplies: 6Last Post: 31-03-2017, 07:43 PM -
Questions on using a moving gantry style mini-mill...
By Davek0974 in forum Machine DiscussionReplies: 183Last Post: 13-07-2016, 06:07 PM -
Vertical moving gantry????
By Ross77 in forum Gantry/Router Machines & BuildingReplies: 9Last Post: 03-06-2009, 08:34 PM
