Thread: Help Please for Moving Gantry
29-10-2017 #4
Most people would recommend a mill style machine for cutting steel as it is possible to build a much stiffer machine as the Z axis is grounded to the base. But there is a limit to the footprint fore aft that it can cut.
Then a gantry machine makes more sense as it can cut much larger pieces but to machine steel it needs to be well built.
The one you linked to looks like a fine general machine but it would not be recommend for steel. Everything needs to be much stiffer including using big profile linear rails not supported round rails etc
I can't remember seeing a gantry machine on this forum designed just for steel so you are not getting much direct advice.
BUILD LOG: Build Log: 4'x4' Moving Gantry CNC Router
By GeorgeW21 in forum DIY Router Build LogsReplies: 14Last Post: 20-01-2019, 09:33 AM -
Beginner Moving Gantry Build? Read This!
By Tenson in forum Gantry/Router Machines & BuildingReplies: 3Last Post: 23-05-2018, 05:30 PM -
Now That's a Serious 4-Axis Moving Gantry Machine!
By magicniner in forum Machine DiscussionReplies: 6Last Post: 31-03-2017, 07:43 PM -
Questions on using a moving gantry style mini-mill...
By Davek0974 in forum Machine DiscussionReplies: 183Last Post: 13-07-2016, 06:07 PM -
Vertical moving gantry????
By Ross77 in forum Gantry/Router Machines & BuildingReplies: 9Last Post: 03-06-2009, 08:34 PM
