Thread: Help Please for Moving Gantry
06-11-2017 #10
Thanks for the Video and I watched it long back, planned to mAke similar one with less in size because of grinding and milling can need on z axis.
anyway here are some questions
I need size of rails and screws
For z axis 20mm linear rails can be ok?
and lead screw how much size should i take?
sample one here https://www.ebay.com/itm/Z-Axis-Line...wwW4n38Qfo6T7g
for x and y axis should i increase 20 to 40mm?
also the same lead screw sizes as the weight would be more sometimes.
First i am going to buy these two things then build the base since these are available in Our local stores.
Waiting for your answer and the size of the base would be 31 inches into 31 or 35 inches sine I dont need the biggest onE presently.
BUILD LOG: Build Log: 4'x4' Moving Gantry CNC Router
By GeorgeW21 in forum DIY Router Build LogsReplies: 14Last Post: 20-01-2019, 09:33 AM -
Beginner Moving Gantry Build? Read This!
By Tenson in forum Gantry/Router Machines & BuildingReplies: 3Last Post: 23-05-2018, 05:30 PM -
Now That's a Serious 4-Axis Moving Gantry Machine!
By magicniner in forum Machine DiscussionReplies: 6Last Post: 31-03-2017, 07:43 PM -
Questions on using a moving gantry style mini-mill...
By Davek0974 in forum Machine DiscussionReplies: 183Last Post: 13-07-2016, 06:07 PM -
Vertical moving gantry????
By Ross77 in forum Gantry/Router Machines & BuildingReplies: 9Last Post: 03-06-2009, 08:34 PM
