Thread: ACP Problem
    Quote Originally Posted by RYANB123 View Post
    Thank you Clive for your quick response. I should have added that the machine
    has a vacuum bed, and this works fine on letters over 6 " tall but will give me grief with smaller letters. Are you suggesting that i should try double sided tape on the vacuum bed? Excuse me if this is stupid, but i am fairly new to this and am on a learning curve (hopefully) Regards Ryan
    Well the smaller the part the less the hold down pressure there is. If you think about it, a part that is 6x6 will have 36 sq" but a part 3x3 will only have 9 sq" so if you have a suction of say 10lb sq" then the 6" part will have a hold down of 360lb but the 3" part will only have 90lb hold down.
    You can use a sacrificial plate (though you will get multiple uses from it) to tape your material to and your vacuum bed will hold the plate nicely.
    - Nick
    Use "holdiing tabs" or don't cut right through the material but leave a very thin skin at the bottom, this will easily clean up later although it is an extra step in the process.
  1. kx 1 problem
    By bab160 in forum Sieg Milling Machines
    Last Post: 31-07-2016, 11:37 AM
  2. help with problem please
    By martin54 in forum General Electronics
    Last Post: 27-08-2014, 09:43 AM
  3. Bearing fit problem
    By paulus.v in forum Linear & Rotary Motion
    Last Post: 09-10-2013, 09:54 AM
  4. Problem with X
    By gorbo in forum General Discussion
    Last Post: 24-02-2011, 05:33 AM
  5. Z Problem
    By airwolf in forum Machine Discussion
    Last Post: 10-11-2009, 08:08 AM
