19-11-2017 #3
As Lee says, engineering is the art of compromise. FWIW, my own thinking was along the lines of...
I want quarter-sheet travel plus a bit of spare. Say, 1400mm. Next bigger off-the-shelf ballscrew available in UK was 1700mm. Use hiwin rails, 1750mm, then 250mm carriage length gives 1500mm travel. 1800mm box section lets me overhang rails off end of machine for end cutting while still keeping adequate bed length for panel work. Just about fits workshop floor area available. And that was more-or-less the design process. Took a few months of cogitating to get there, mind you, but in the grand scheme of things, 50mm extra bearing spacing costs almost nothing, adds little to size, and gives that slight feeling of doing the right thing. Y carriage width looks about right at 200mm for 750mm travel on 950mm gantry (inside dimensions).
In the end, the decision often comes down to some simple key facts and you just have to work out what the real decision factors are. Like stepper motor sizing - for this size machine, you can analyse and calculate as much as you like, but the answer will be 3 or 4Nm Nema 23 motors with a 68V psu. You don't use bigger motors because they are heavier and slower, and smaller motors aren't that much cheaper.
Sometimes the engineer in me overcomes the need to analyse to death and at least you can then start building!Last edited by Neale; 19-11-2017 at 10:17 AM.
NEW MEMBER: Hi and a couple of questions.
By TheBoltonian in forum New Member IntroductionsReplies: 4Last Post: 08-01-2017, 05:58 PM -
hi all, new to cnc building,couple of questions if anyone can help. TIA
By universally in forum Gantry/Router Machines & BuildingReplies: 14Last Post: 18-01-2015, 04:12 PM -
RFQ: Z axis and y axis carriage
By D-man in forum Projects, Jobs & RequestsReplies: 0Last Post: 08-04-2013, 10:06 AM -
Reinforced plastic beams for x-axis rails ?
By flanagaj in forum Gantry/Router Machines & BuildingReplies: 3Last Post: 19-10-2011, 05:28 PM -
x-axis rails and lead screw
By adambrum in forum Gantry/Router Machines & BuildingReplies: 1Last Post: 13-08-2011, 01:56 PM
