    If you are trying to put the screw close over the linear blocks, why don't you sink the nut in to the plate and drop the screw down? How are you going to keep the cuttings out of the screws? You have made it from heavy section to cut aluminium but that will not help you get the speed to cut wood efficiently. If your gantry weighs 50 lbs then you need 50 lbf plus the cutting force to accelerate it at one G.
    OTOH I think you need to build something wrong and then fix it with the Mk2. Understanding CNC design does rather come with experience. Getting it wrong is not actually a bad idea.
    I don't follow you here. Do you mean machine a pocket into the plate in order to get the ball nut lower (i.e, closer to the linear carriages)?
    Guards, covers, bellows. They aren't shown.
    I don't follow you here. You seem to say it won't be fast enough by saying it won't accelerate enough - is that what you mean? Regardless, I assume there is always a servo strong enough. Some of the machines I sell (for my day job) weigh over 30,000 kg and can accel at 1G. Of course those motors are huge... I'm personally looking at the Clearpath servos. Nema 23 and 34 frame sizes.
    I think that's sage advice. What part are you seeing that is wrong?
    Why not put the screw inside the frame
    Lives in Plymouth, United Kingdom. Last Activity: 2 Hours Ago Has a total post count of 1,748. Received thanks 299 times, giving thanks to others 11 times.
    I would consider moving the ballscrews just outboard of the ends of the gantry. This allows a more rigid fixing of gantry to carriage feet. If the ballscrew mounts are on outrigger brackets welded to the outside of the frame tubes, mounting pads for the ballscrew bearings could be machined at the same setting as the frame tubes. There is no benefit in having the ballscrews over the slides as a gantry driven at both ends is balanced anyway. It's not like the gantry ballscrew which is more difficult to fit between the linear rails.
    The idea of being able to machine the top of the long rails is so far from reality for most of us that I doubt if many have designed for that! I'm in the "if I can't machine it, build in adjustment" camp...
    Great point and idea. I'll try to mock something up. I am definitely motivated by making the machining of the machine as straightforward as possible and only requiring a vertical mill. When I see machines, similar to what I just mocked up except the ballscrews are outside of the frame, mounted to the outside frame vertical wall, this is either (1) asking for a large boring mill or horizontal machining center, with (2) multiple setups, just to machine the ballscrew mounting pads. That starts to add up fast. Or the pads are painstakingly fitted by hand with shims and numerous iterations of racking the gantry back and forth to get alignment, and then I question how flat and parallel the mounting surfaces can be.
    I am surprised to read this. Granted, my machine is a little on the small side compared to many I see here, but it will fit on an 80" x 40" machine. The going shop rate is $60/hour near me, so I am counting on all the machining work coming in just a few hundred $. Given how much money people invest into designing and building their own CNC routers, I would thinking have the rail surfaces and mounting pads machined would be easy to justify.
    My current machine uses something similar. I was trying to get the gantry sides as stiff as possible, and make a good connection to the rails. Fitting the ballscrew in there as well was just convenient.
    Haven't seen that before. Great job!
    Quote Originally Posted by Bravin Neff View Post
    It's an interesting point, and I wonder if there is a difference between UK and US here. I have no idea where I would go to find a jobbing engineering shop anywhere near me, let alone one with that kind of capacity. My own machine top rails are roughly 1.8m long, 1m separation, on a floor-mounted machine. It would be great to have had that machined but like most (UK) folks on this forum, I ended up with an epoxy bed instead. My background is IT so I have very few contacts in the engineering world - I wonder if anyone else knows how likely/easy it would be to find machining capacity like that, available at an acceptable cost, in the UK?
    I am sure regional differences apply, and not just between countries. Where I live and work, there are over 800 CNC machine shops within a 50 mile radius of where I live. I also have colleagues elsewhere in the country that have to travel 500 miles in order to reach fewer shops. I am sure there are hot spots in the UK for manufacturing.
  1. Ball screw advice
    By Darren in forum Lead Screws, Nuts & Supports
    Last Post: 10-04-2016, 10:52 PM
  2. How to machine a ball screw
    By Tom_Nelson in forum Milling Machines, Builds & Conversions
    Last Post: 22-07-2015, 10:50 AM
  3. Replies: 4
    Last Post: 02-01-2015, 08:32 AM
  4. Ball screw
    By luke11cnc in forum Lead Screws, Nuts & Supports
    Last Post: 20-10-2011, 01:28 PM
  5. Stationary Ball Screw
    By Wobblybootie in forum Lead Screws, Nuts & Supports
    Last Post: 29-12-2009, 01:12 PM
