    Quote Originally Posted by Bravin Neff View Post
    I am surprised to read this. Granted, my machine is a little on the small side compared to many I see here, but it will fit on an 80" x 40" machine. The going shop rate is $60/hour near me, so I am counting on all the machining work coming in just a few hundred $. Given how much money people invest into designing and building their own CNC routers, I would thinking have the rail surfaces and mounting pads machined would be easy to justify.
    It's an interesting point, and I wonder if there is a difference between UK and US here. I have no idea where I would go to find a jobbing engineering shop anywhere near me, let alone one with that kind of capacity. My own machine top rails are roughly 1.8m long, 1m separation, on a floor-mounted machine. It would be great to have had that machined but like most (UK) folks on this forum, I ended up with an epoxy bed instead. My background is IT so I have very few contacts in the engineering world - I wonder if anyone else knows how likely/easy it would be to find machining capacity like that, available at an acceptable cost, in the UK?
    I am sure regional differences apply, and not just between countries. Where I live and work, there are over 800 CNC machine shops within a 50 mile radius of where I live. I also have colleagues elsewhere in the country that have to travel 500 miles in order to reach fewer shops. I am sure there are hot spots in the UK for manufacturing.
    Every little job that I have deemed would benefit from machining (generally milling or surface grinding) I have received exorbitant quotes for (I believe they are known as 'F**K OFF' quotes). The main reason given that setting up is the bulk of the work (£200 ish min) and so a one-off job is not economically viable.
    If I wanted 1000+ machining, then I would guess the set-up would be amortized quite magically.
    Basically, finding a small machine shop in UK that is struggling for work and prepared to talk sensible pricing for small jobs, seems to be difficult.
  4. The Following User Says Thank You to cropwell For This Useful Post:
  1. Ball screw advice
    By Darren in forum Lead Screws, Nuts & Supports
    Last Post: 10-04-2016, 10:52 PM
  2. How to machine a ball screw
    By Tom_Nelson in forum Milling Machines, Builds & Conversions
    Last Post: 22-07-2015, 10:50 AM
  3. Replies: 4
    Last Post: 02-01-2015, 08:32 AM
  4. Ball screw
    By luke11cnc in forum Lead Screws, Nuts & Supports
    Last Post: 20-10-2011, 01:28 PM
  5. Stationary Ball Screw
    By Wobblybootie in forum Lead Screws, Nuts & Supports
    Last Post: 29-12-2009, 01:12 PM
