05-11-2017 #11
I might not be understanding you correctly, but I think you have in mind either gussets between the horizontal and vertical plates, or what I have been imagining, a small vertical detail that connects the horizontal plate with the Gantry, which would fully box in the ballscrew mount and ballscrew. I have been leaning away from that, because the design as is leaves that surface (the horizontal one that the ballscrew mount attaches to) fully exposed on a vertical machining center, making it easy to backside machine. In other words, I am trying to balance the design with ease of Machining these details.
If you can imagine this entire Gantry as one welded fabbed unit, then putting it on a vertical Machining Center, upside down, makes the rail Carriage surfaces easy to machine flat, and then you can back side machine the opposite side, making the ball screw Mount Services flat as well.
Ball screw advice
By Darren in forum Lead Screws, Nuts & SupportsReplies: 7Last Post: 10-04-2016, 10:52 PM -
How to machine a ball screw
By Tom_Nelson in forum Milling Machines, Builds & ConversionsReplies: 10Last Post: 22-07-2015, 10:50 AM -
A couple of general design questions - ball-screw thread length, stub-shaft etc.
By Wal in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 02-01-2015, 08:32 AM -
Ball screw
By luke11cnc in forum Lead Screws, Nuts & SupportsReplies: 5Last Post: 20-10-2011, 01:28 PM -
Stationary Ball Screw
By Wobblybootie in forum Lead Screws, Nuts & SupportsReplies: 14Last Post: 29-12-2009, 01:12 PM
