06-11-2017 #21
It's an interesting point, and I wonder if there is a difference between UK and US here. I have no idea where I would go to find a jobbing engineering shop anywhere near me, let alone one with that kind of capacity. My own machine top rails are roughly 1.8m long, 1m separation, on a floor-mounted machine. It would be great to have had that machined but like most (UK) folks on this forum, I ended up with an epoxy bed instead. My background is IT so I have very few contacts in the engineering world - I wonder if anyone else knows how likely/easy it would be to find machining capacity like that, available at an acceptable cost, in the UK?
06-11-2017 #22
06-11-2017 #23In nearly 15 years of reading a majority of the DIY forums daily, I can count on one hand the number of people who have had their welded frames machined.I am surprised to read this. Granted, my machine is a little on the small side compared to many I see here, but it will fit on an 80" x 40" machine. The going shop rate is $60/hour near me, so I am counting on all the machining work coming in just a few hundred $. Given how much money people invest into designing and building their own CNC routers, I would thinking have the rail surfaces and mounting pads machined would be easy to justify.
The reasons, as stated above, are probably that most people don't know where they could have it done, at a reasonable cost.Gerry
UCCNC 2022 Screenset
Mach3 2010 Screenset
The Following User Says Thank You to Ger21 For This Useful Post:
06-11-2017 #24
I am sure regional differences apply, and not just between countries. Where I live and work, there are over 800 CNC machine shops within a 50 mile radius of where I live. I also have colleagues elsewhere in the country that have to travel 500 miles in order to reach fewer shops. I am sure there are hot spots in the UK for manufacturing.
06-11-2017 #25
I am sure you are right. I have also noticed there seems to be very little overlap between the DIY CNC world and the commercial CNC world. I have worked and operated CNC machines my entire working life, but only have discovered the DIY world a few months ago. And now that I'm excited by it, I talk about it all the time with colleagues and customers, and I have yet to come across a single one of them that knows anything about it or who dabbles in it. I find that remarkable.
06-11-2017 #26
Every little job that I have deemed would benefit from machining (generally milling or surface grinding) I have received exorbitant quotes for (I believe they are known as 'F**K OFF' quotes). The main reason given that setting up is the bulk of the work (£200 ish min) and so a one-off job is not economically viable.
If I wanted 1000+ machining, then I would guess the set-up would be amortized quite magically.
Basically, finding a small machine shop in UK that is struggling for work and prepared to talk sensible pricing for small jobs, seems to be difficult.
The Following User Says Thank You to cropwell For This Useful Post:
08-10-2018 #27
you're on to something there but as the otehr members said the weak point is the upright plate with no bracing for side to side loads. here's the same concept with one form of bracing added to what you initially drew
i like the idea it's very clever & done right could be quite sturdy
08-10-2018 #28
Ball screw advice
By Darren in forum Lead Screws, Nuts & SupportsReplies: 7Last Post: 10-04-2016, 10:52 PM -
How to machine a ball screw
By Tom_Nelson in forum Milling Machines, Builds & ConversionsReplies: 10Last Post: 22-07-2015, 10:50 AM -
A couple of general design questions - ball-screw thread length, stub-shaft etc.
By Wal in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 02-01-2015, 08:32 AM -
Ball screw
By luke11cnc in forum Lead Screws, Nuts & SupportsReplies: 5Last Post: 20-10-2011, 01:28 PM -
Stationary Ball Screw
By Wobblybootie in forum Lead Screws, Nuts & SupportsReplies: 14Last Post: 29-12-2009, 01:12 PM
