Every little job that I have deemed would benefit from machining (generally milling or surface grinding) I have received exorbitant quotes for (I believe they are known as 'F**K OFF' quotes). The main reason given that setting up is the bulk of the work (£200 ish min) and so a one-off job is not economically viable.
If I wanted 1000+ machining, then I would guess the set-up would be amortized quite magically.
Basically, finding a small machine shop in UK that is struggling for work and prepared to talk sensible pricing for small jobs, seems to be difficult.
The Following User Says Thank You to cropwell For This Useful Post:
Ball screw advice
By Darren in forum Lead Screws, Nuts & SupportsReplies: 7Last Post: 10-04-2016, 10:52 PM -
How to machine a ball screw
By Tom_Nelson in forum Milling Machines, Builds & ConversionsReplies: 10Last Post: 22-07-2015, 10:50 AM -
A couple of general design questions - ball-screw thread length, stub-shaft etc.
By Wal in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 02-01-2015, 08:32 AM -
Ball screw
By luke11cnc in forum Lead Screws, Nuts & SupportsReplies: 5Last Post: 20-10-2011, 01:28 PM -
Stationary Ball Screw
By Wobblybootie in forum Lead Screws, Nuts & SupportsReplies: 14Last Post: 29-12-2009, 01:12 PM
