Is there anyone in Scotland using a cnc similar to what I've described who would consider letting me have a look at their setup. I think I need some hands on advice.
17-02-2018 #2
Hi Jiroma,
I am also new by taking the leap back in November but have stumbled at the first hurdle, I brought a cnc machine before discovering this site so your already made the first step safely by getting expert advice via here (not me but a lot of others on here)
I can only advise caution I brought what seemed to be a good deal the CNC 6040 machine (60cm by 40cm table size) from Germany for £880.
The CNC 6040, 3040 range are made in China and have a reputation for shoddy software or electrical parts, I found this out after I brought mine.
My machine has had issues and I have yet to use it since purchasing back in November and after a lot of questioning on here and testing my main panic was settled (my machine sounded as if it had a mechanical fault) however I have narrowed it down to an electrical board so cheapish to replace but its been a lot of hassle.
When I searched on Youtube I found this was a common issue with them as China have different standards for electrical compliances so although it all looks nice and neat there are a few issues you need to sort out such as cable shielding, cheap components and everything crammed in a nice little box.
I wouldn't say avoid a CNC 6040 altogether I just exercise precaution to expect to tinker with it.
You will find a lot of good advice from here by the others as there is a lot of knowledgeable and experienced members.
Hope you find what you are looking for and good luck with the woodworking, that's what I am into as well mainly.
Kind Regards
Graham
17-08-2018 #3
Hey Graham,
Did you buy on ebay? Wht was the name of the seller if so?
17-08-2018 #4You think that's too expensive? You're not a Model Engineer are you? :D
17-08-2018 #5
I've read the wiring and reliability in the 800w machines is better. I was trying for an educated pot luck choice :-)
17-08-2018 #6
I need Help I need to get a decent CNC machine don't have to much to spend
By theceo in forum Woodwork DiscussionReplies: 50Last Post: 06-06-2016, 07:53 AM -
RFQ: Can someone make this for me? For money?
By richardmayo in forum Projects, Jobs & RequestsReplies: 1Last Post: 16-11-2013, 02:00 AM -
BUILD LOG: small mill for machining steel. Max spend £500 including computer
By Andrew Wilding in forum DIY Mill Build LogsReplies: 44Last Post: 20-07-2012, 03:46 PM -
Which part of *your* build leaked the most money?
By CNCBlug in forum General DiscussionReplies: 3Last Post: 08-03-2010, 07:59 PM -
Easy money
By HankMcSpank in forum General DiscussionReplies: 2Last Post: 06-07-2009, 12:39 PM
