Dear all
Hope someone can help.
My Emco Turn 55 had not been used for over 5 years. I finally got round to starting it. When executing a cutting program, the XZ and toolchanger all worked as programmed but the lathe will give a high pitch whine that last for maybe 1-2 seconds or so and then an error message pops up to say "no main spindle speed". The spindle did not move even a bit.
I took out the back panel to check on the Lenze 8200 Inverter Drive. When I switch on the PC Turn, immediately the Lenze Inverter Green LED started blinking and continue to blink nonstop. It will go solid green when it tried to execute the M3 code and whine. Once the whine stopped, it goes back to blinking.
I downloaded Lenze manual and it said that it could be "Motor parameter identification being executed" or it could be "Controller Inhibited". I am not sure what either of that means. Could it be that the spindle motor parameter has to be reentered into the Lenze because the memory for the spindle motor was lost?
Any help is greatly appreciated.
frank
07-11-2017 #2
Have you manually followed the process for "commissioning" the VFD?
07-11-2017 #3
It could also be that the Capacitors need reforming
07-11-2017 #4
Thanks for replies.
Magicniner- The inverter is original equipment that was built in by Emco and the spindle was working properly before the prolonged storage. so i did not do any commissioning when i powered up the cnc lathe.
Eddycurrent - do you know if the lenze relies on batteries to remember motor parameters? how does the capacitor reforming help and how do i go about doing it?
07-11-2017 #5
08-11-2017 #6
I don't know about the battery but there is information here, for example, about capacitors; https://www.youtube.com/watch?v=HuALonM_1X4
Roughly speaking a VFD goes from AC input, through a recifier to what is called the DC bus and the capacitors there act as a reservoir before the DC is chopped up into a synthesised sine wave of variable frequency.
I've just seen on page 28 of the manual; http://download.lenze.com/TD/E82EV__...__v3-0__EN.pdf
it says; Storage > 2 years: form the DC bus capacitors.
Page 202 of the manual goes on to say;
Stop!
Special commissioning procedure after long−term storage
If controllers are stored for more than two years, the insulation resistance of
the electrolyte may have changed.
Possible consequences:
ƒ During initial switch−on, the DC−bus capacitors and hence the controller are
damaged.
Protective measures:
ƒ Form the DC−bus capacitors prior to commissioning. Instructions can be
found on the Internet (www.Lenze.com).Last edited by EddyCurrent; 08-11-2017 at 02:59 PM.
12-11-2017 #7
Or maybe nobody cares any more ?
13-11-2017 #8
thanks for the info. appreciate you taking time to send them. i had to travel so didn't have time to log in to check forum.
looking at the info, it seems quite daunting a task to to recommission a machine from long storage :-(
Lenze i500 Inverter
By brandon_costa in forum Motor Drivers & ControllersReplies: 2Last Post: 20-04-2017, 10:02 PM -
1.5KW Spindle and Inverter with collet set 4 months old £120
By adamh in forum Classified Ads, Buy, Sell & SwapReplies: 1Last Post: 22-08-2015, 10:53 PM -
Advice on spindle inverter spec
By badgerman in forum Spindles & Drive MotorsReplies: 12Last Post: 15-09-2013, 09:26 PM -
50/60 volt spindle inverter.
By GEOFFREY in forum Spindles & Drive MotorsReplies: 0Last Post: 24-12-2012, 03:58 PM -
FOR SALE: 2.2KW Water Cooled Spindle + Inverter (yes the Chinese one!)
By Bokoshoko in forum Items For SaleReplies: 3Last Post: 06-02-2012, 12:43 PM
