12-11-2017 #2
Looks OK in general and will work. Some comments:
Kress is noisy, have a look at the water cooled spindles with VFD drive, 1.5kW or 2.2kW. This will also have a better mounting surface than the Kress which is just held by a small collar area.
Make sure you have a way of adjusting the position of one of the X rail supports on the bed because you have trapped the X rails between the gantry sides, defining the position they need to be in. Easiest way would be to make the holes for one of the bed side profiles on the bed end plate slightly larger than the bolts.
Z axis rails and carriages can be swapped around to give more support. Put the rails on the Z plate and carriages on the Y.
20mm and 15mm plate will be OK. I've tended to use 6061 grade aluminium.
Opinions on this router design
By NB70 in forum Gantry/Router Machines & BuildingReplies: 13Last Post: 20-10-2017, 08:33 PM -
Triangular gantry design - opinions wanted
By andrew 2000 in forum Gantry/Router Machines & BuildingReplies: 1Last Post: 18-10-2017, 10:40 PM -
Opinions/Advice on my 800 x600 design
By davegrennan in forum Gantry/Router Machines & BuildingReplies: 8Last Post: 10-07-2015, 12:03 AM -
Design ideas finally drawn up for your opinions please
By Hopey in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 25-03-2015, 10:10 PM -
Opinions sought on cheap desktop PCB milling machine
By ksangeelee in forum Milling Machines, Builds & ConversionsReplies: 55Last Post: 16-03-2012, 01:57 PM
