I am making small side tables out of 12mm MDF with oak veneer on both sides, realise an up or down spiral cut will not get a good edge on one of the sides.
Looking at 6mm compression and straight 2 blade flutes.
These seem to be very expensive. Does any one know of a supplier who does them at a reasonable price?
I know not to use HSS. Only carbide. I have purchased up /down cut ones (that are very cheap and lasted well). Just cant find compression ones.
Thanks.Last edited by Millatime16; 11-11-2017 at 03:23 PM.
11-11-2017 #2
http://www.completecnc.co.uk/CNC-Woo...ession-Cutters
https://routercutter.co.uk/up-down-c...-2-compression
http://www.dpcnc.co.uk/product/pct-c...utters-2-flute
You might also consider 2flute cutters with a 15 deg spiral https://www.sorotec.de/shop/Cutting-...END-Mill-WOOD/Last edited by cropwell; 11-11-2017 at 09:14 PM.
Feeds and speeds settings for compression spiral
By Metal pecker in forum General DiscussionReplies: 2Last Post: 02-07-2016, 06:41 PM -
Compression Bit Advice
By dcrowder in forum Machine DiscussionReplies: 4Last Post: 17-04-2016, 10:27 PM -
Machine Light(Lathe) anything reasonably priced
By mekanik in forum Workshop & EquipmentReplies: 17Last Post: 24-02-2016, 07:58 PM -
Has anyone used this Chinese supplier?
By D.C. in forum Marketplace DiscussionReplies: 0Last Post: 29-07-2015, 01:37 PM -
Can you recommend a UK Supplier for cnc router bits
By GeoDurie in forum Tool & Tooling TechnologyReplies: 0Last Post: 06-06-2014, 10:40 AM
