Can you post an extract of the gcode showing an example of where it happens? One of the pairs of eyes reading this forum might spot the problem. Is it only while actually cutting, or does it also happen when "air cutting"?
13-11-2017 #2
Will try too tomorow it happens with both however I’m only cutting foam at the moment so it’s not exactly loaded up. It has been fine cutting one file all summer but now it’s not. Perhaps the cold has effected the motors?
13-11-2017 #3
would it be likely that it is the motor/driver that is giving the fault that is likely to be the problem or that its one of the others that is doing it? I have y and z axis both using a em806 and the x using a much larger kinco drive
EM806 drivers
By phill05 in forum General DiscussionReplies: 5Last Post: 02-07-2017, 04:11 PM -
AM882 strange sensorless stall detection issue
By Gotty101 in forum Motor Drivers & ControllersReplies: 10Last Post: 29-06-2016, 09:13 PM -
Laser Machine Eye protection
By Want2build1 in forum Laser Machines & BuildingReplies: 11Last Post: 19-05-2014, 01:46 PM -
Digital Drivers and Stall Detection
By Washout in forum Motor Drivers & ControllersReplies: 6Last Post: 10-12-2013, 05:02 PM -
overload protection
By pedroh in forum Tool & Tooling TechnologyReplies: 4Last Post: 19-07-2012, 06:17 PM
