18-02-2018 #51
If notice there's nothing in there which actually moves the turret etc. Still needs code adding. Better example is to look at this link and download the file.
http://centroidcncforum.com/viewtopi...lit=turret+atc
18-02-2018 #52
Copied:-
TurretMotor is an output. It turns on if currentPosition_W != RequestedLocation_W.
;If current position != requested position, rotate turret
IF DoingTurretIndex_M && RequestedLocation_W != CurrentTurretPosition_W THEN SET TurretMotor
Not sure where or how this TurretMotor is defined. On my Triac, that was just an output for a relay, so that's easy. This is different as its actually the A Axis and not an 'outside' device.
18-02-2018 #53
18-02-2018 #54
I'll just put this here for now, but it's a work in progress. I need to go and do something, but will try and get it finished later.
Original code-
Code:;============================================================================= MainStage ;============================================================================= ;Do gather if commanded (uncomment and recompile for debugging purposes) ;IF Aux11Key || ((SV_MPU11_ABS_POS_2 < SV_MACHINE_PARAMETER_45) && (SV_MACHINE_PARAMETER_45 < -1000)) THEN (Aux11KeyPD) ;IF Aux11KeyPD THEN (SV_TRIGGER_PLOT_DUMP), SET SV_STOP ;IF Aux11Key || OUT25 THEN (SV_TRIGGER_PLOT_DUMP) IF TRUE THEN CurrentTurretPosition_W = 0 IF ToolBit1 && ToolBit2 && !ToolBit3 THEN CurrentTurretPosition_W = 1 IF !ToolBit1 && ToolBit2 && !ToolBit3 THEN CurrentTurretPosition_W = 2 IF !ToolBit1 && !ToolBit2 && !ToolBit3 THEN CurrentTurretPosition_W = 3 IF ToolBit1 && !ToolBit2 && !ToolBit3 THEN CurrentTurretPosition_W = 4 IF ToolBit1 && !ToolBit2 && ToolBit3 THEN CurrentTurretPosition_W = 5 IF !ToolBit1 && !ToolBit2 && ToolBit3 THEN CurrentTurretPosition_W = 6 IF !ToolBit1 && ToolBit2 && ToolBit3 THEN CurrentTurretPosition_W = 7 IF ToolBit1 && ToolBit2 && ToolBit3 THEN CurrentTurretPosition_W = 8 IF TRUE THEN SV_PLC_CAROUSEL_POSITION = CurrentTurretPosition_W IF SV_PROGRAM_RUNNING THEN (ProgramRunning) ;cnctch.mac IF OnAtPowerUp_M THEN RequestedLocation_W = CurrentTurretPosition_W IF TRUE THEN TurretTimer = 700, ReversingTimer = 1500 IF M6 THEN (M6PD), SET DoingTurretIndex_M IF M6PD THEN RequestedLocation_W = SV_TOOL_NUMBER IF DoingTurretIndex_M && ((SV_TOOL_NUMBER < 1) || (SV_TOOL_NUMBER > 8)) THEN SET OtherFault_M, FaultMsg_W = INVALID_TOOL_NUMBER, RST DoingTurretIndex_M, RequestedLocation_W = CurrentTurretPosition_W, SET ToolChangeComplete IF DoingTurretIndex_M && RequestedLocation_W != CurrentTurretPosition_W THEN SET TurretMotor IF RequestedLocation_W == CurrentTurretPosition_W THEN SET TurretTimer IF TurretTimer THEN RST TurretMotor, SET ReversingTimer, RST TurretTimer IF ReversingTimer THEN RST ReversingTimer, SET ToolChangeComplete IF !SV_PROGRAM_RUNNING THEN RST M6, RST DoingTurretIndex_M, RequestedLocation_W = CurrentTurretPosition_W IF !M6 THEN RST ToolChangeComplete, RST TurretTimer IF SV_STOP THEN RST TurretMotor, RST TurretTimer, RST ReversingTimer, RST M6
Code in the process of being modified
RequestedLocation_WCode:;============================================================================= MainStage ;============================================================================= ;Do gather if commanded (uncomment and recompile for debugging purposes) ;IF Aux11Key || ((SV_MPU11_ABS_POS_2 < SV_MACHINE_PARAMETER_45) && (SV_MACHINE_PARAMETER_45 < -1000)) THEN (Aux11KeyPD) ;IF Aux11KeyPD THEN (SV_TRIGGER_PLOT_DUMP), SET SV_STOP ;IF Aux11Key || OUT25 THEN (SV_TRIGGER_PLOT_DUMP) IF SV_PROGRAM_RUNNING THEN (ProgramRunning) ;cnctch.mac IF OnAtPowerUp_M THEN RequestedLocation_W = CurrentTurretPosition_W IF TRUE THEN TurretTimer = 700, ReversingTimer = 1500 IF M6 THEN (M6PD), SET DoingTurretIndex_M IF M6PD THEN RequestedLocation_W = SV_TOOL_NUMBER IF DoingTurretIndex_M && ((SV_TOOL_NUMBER < 1) || (SV_TOOL_NUMBER > 8)) THEN SET OtherFault_M, FaultMsg_W = INVALID_TOOL_NUMBER, RST DoingTurretIndex_M, RequestedLocation_W = CurrentTurretPosition_W, SET ToolChangeComplete ;code to calculate distance to move If CurrentTurretPosition_W > RequestedLocations_W THEN DistanceToMove = ... (need to handle roll over) ;code to rotate A-axis require distance ;code to reverse A-axis IF TRUE THEN SET ToolChangeComplete IF !SV_PROGRAM_RUNNING THEN RST M6, RST DoingTurretIndex_M, RequestedLocation_W = CurrentTurretPosition_W IF !M6 THEN RST ToolChangeComplete, RST TurretTimer IF SV_STOP THEN RST TurretMotor, RST TurretTimer, RST ReversingTimer, RST M6
Chaz, to save me looking it up, just to confirm, it's an 8-position turret (45 deg between tools)?
And does normal rotation increase or decrease tool position?Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
18-02-2018 #55
18-02-2018 #56
Just looked at a pic. It looks like the numbers decend.
19-02-2018 #57This is the barebones of what should be needed I think.Code:
;============================================================================= MainStage ;============================================================================= ;Do gather if commanded (uncomment and recompile for debugging purposes) ;IF Aux11Key || ((SV_MPU11_ABS_POS_2 < SV_MACHINE_PARAMETER_45) && (SV_MACHINE_PARAMETER_45 < -1000)) THEN (Aux11KeyPD) ;IF Aux11KeyPD THEN (SV_TRIGGER_PLOT_DUMP), SET SV_STOP ;IF Aux11Key || OUT25 THEN (SV_TRIGGER_PLOT_DUMP) IF SV_PROGRAM_RUNNING THEN (ProgramRunning) ;cnctch.mac IF OnAtPowerUp_M THEN RequestedLocation_W = CurrentTurretPosition_W IF TRUE THEN TurretTimer = 700, ReversingTimer = 1500 IF M6 THEN (M6PD), SET DoingTurretIndex_M IF M6PD THEN RequestedLocation_W = SV_TOOL_NUMBER IF DoingTurretIndex_M && ((SV_TOOL_NUMBER < 1) || (SV_TOOL_NUMBER > 8)) THEN SET OtherFault_M, FaultMsg_W = INVALID_TOOL_NUMBER, RST DoingTurretIndex_M, RequestedLocation_W = CurrentTurretPosition_W, SET ToolChangeComplete ;code to calculate distance to move IF CurrentTurretPosition_W > RequestedLocation_W THEN PositionsToMove_W = CurrentToolPosition_W - RequestedLocation_W IF CurrentTurretPosition_W < RequestedLocation_W THEN PositionsToMove_W = (CurrentTurretPosition_W + 8) - RequestedLocation_W ;this assumes the PLC can handle ELSE.. IF TRUE THEN DistanceToMove_W = PositionsToMove_W * 45 ; This may need a further multiplication if we're not going to be moving in degrees (does this need extra movement to overshoot new position before reversing?) ;code to rotate A-axis require distance ;code to reverse A-axis IF TRUE THEN SET ToolChangeComplete IF !SV_PROGRAM_RUNNING THEN RST M6, RST DoingTurretIndex_M, RequestedLocation_W = CurrentTurretPosition_W IF !M6 THEN RST ToolChangeComplete, RST TurretTimer
It still needs the required code to actually move the A-axis.
Also see the notes I've added.
Having scanned through the manual, I can't see how, or even if, you can move an axis via the PLC.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
19-02-2018 #58
I've just realised, what you need to achieve may have to be via a combination of Macro and PLC.
The macro allows you to run normal G-codes, but I'm not sure if you can run calculations in a Macro.
What you may need to do, is run the Macro, which then moves to the PLC to calculate the rotation required, which is then stored in a variable the macro can access. The macro then carries out the required A axis movement.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
19-02-2018 #59
19-02-2018 #60
So some response from the Centroid forum. Explained the logic to him. It looks like I need to buy the software to get access to the M107 command needed for the BCD Tool Changer Output. Happy to buy it but need to know I can get it to work.
Centroid Acorn DIY CNC controller
By NB70 in forum Control Hardware & SystemsReplies: 3Last Post: 15-11-2017, 02:14 PM -
Centroid Acorn CNC Controller
By wallyblackburn in forum Gantry/Router Machines & BuildingReplies: 22Last Post: 29-10-2017, 12:28 PM -
Controller Cabinet
By cropwell in forum Workshop & EquipmentReplies: 2Last Post: 19-12-2015, 02:23 PM -
FOR SALE: Controller Box for sale
By lateAtNight in forum Items For SaleReplies: 12Last Post: 04-03-2012, 10:17 AM -
Controller Box
By M250cnc in forum Motor Drivers & ControllersReplies: 1Last Post: 21-11-2010, 01:34 AM
