Thread: Control Panel nearly done!
13-11-2017 #1
What do you think?
Just a bit wiring needed, then some gaffer tape onto the side of the machine, and I'll be good to go
13-11-2017 #2
Shouldn't that big red knob be labeled 'Oh F**k', but I do think you have overcomplicated things,
13-11-2017 #3
I'll get a fresh Sharpie out once it's all fitted for the labelling.
From top left to right, I think it's these labels-
Big dial - Move.
Little knob one - Lefty/Righty, Inny/Outty, Uppy Downy (plus spinny aroundy for the 4th axis option)
Little knob two - Wee nudge, Wee Baw Hair, Big Baw Hair, Big Nudge
Big knob one - No as fast, Faster
Big know two - Quiet, Loud
Red Button - Whoa!
Green Button - Go!
Big Red Button - S***e!Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
13-11-2017 #4
Like it ! Puts mine to shame and makes it look over-considered.
Can't wait for you to hit that estop and punch it through the panel whilst your machine carries on !
13-11-2017 #5
That's a posh box, I think you may have over-engineered it! :D
13-11-2017 #6
13-11-2017 #7
I've been umming and arring over the control panel for a while, and having finally finished all the major cabinet wiring and programming last week, it has reached the top of my roundtuit list.
While contemplating button/dial placement, I happened to notice the box which was about the size I had in my head. So after rounding up all the bits, I got the scissors out tonight. I was going to put the axis/step size select switches above the MPG, but having tested the layout, I felt the MPG would be too easy to knock while working the switches, which is why all that seems a bit bunched up.
I'm going to put a handle along below the buttons, so I can rest my hand on it while working the MPG.
Next step is modelling it in Fusion.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
14-11-2017 #8
You'll be needing the Mach Tavish plug-in Dr Finlay !
14-11-2017 #9
I'm actually surprised to read this thread here and now - I'm in the process of replacing a panel on the starmill that had a single E-Stop button with one with a full axis/mpg and DRO indicators, and just last night started learning F360 and mocking up the panel.
I might nick the alternative E-Stop label, though
15-11-2017 #10
Doddy, I've done various sketches for control panels, but I really wanted to test the layout, as that's the only way you can get a proper feel for how it'll work.
Like the MPG/selector switch thing. The selector switches above makes sense from a visibility view, as it means their labels would be more visible, however as I mentioned, trying them with the mock-up, it felt like I had to make an effort to lift my hand up, over and clear of the MPG to move them to avoid using the MPG itself as a steady for my hand.
This will be getting coupled with just a touchscreen. I will have USB ports on the housing should I want to connect a keyboard/mouse, however I've got no plan to have them permanently connected, as I'm aiming for most things to be done via the touchscreen, with only physical buttons for critical functions.
I am currently considering not even having the axis/step size select switches, as I've seen a way of adding that functionality to a touchscreen in a way that I think will work well (the new screen designer for KMotionCNC has opened up a lot of options!). If it works, it will save me a good bit of fiddly wiring, as the connectors on the selector switches have to be soldered, with a terminal for each position you want to use.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
Setting Up A Control Panel
By GTJim in forum Machine DiscussionReplies: 0Last Post: 13-08-2015, 09:53 AM -
Mach 3 control panel help
By IanParkin in forum Artsoft Mach (3 & 4)Replies: 19Last Post: 05-09-2014, 04:05 PM -
Control Panel Guidance
By GTJim in forum General ElectronicsReplies: 2Last Post: 03-09-2013, 08:42 PM -
RFQ: Aluminium Control Panel
By m_c in forum Projects, Jobs & RequestsReplies: 5Last Post: 27-04-2013, 08:46 PM -
Advice Needed - Control Panel
By GTJim in forum General ElectronicsReplies: 0Last Post: 18-04-2013, 08:23 AM
