    here; https://www.toolstation.com/shop/Pow...traight/p67412
    You should use a spiral lead-in because they are not designed to plunge straight down, I use them all the time.
    Thanks, but isn't that a router bit? I'm talking CNC btw.
    Ha, the router bit has no idea nor cares whether you are using a router or a cnc, in fact I'm suprised you thought there was a difference. (where we are talking about wood products)
    Sorry I thought they were different. I just found a straight fluted mill bit that can plunge (specifically for CNC). Will give one of those a try. Thanks for suggestion. :)
    Plunging is fine but there comes a time when you should look at lead-in moves. What CAM software are you using ?
    I would only be plunging 6mm holes and the start of the table edge. I am using V Carve and Mach 3
    spiral or ramp it in, I have been getting the real cheap ones from banggood and had good results and about £1-3 each depending on size
    Quote Originally Posted by charlieuk View Post
    Carbide or HSS?
    carbide
  1. NEW MEMBER: Greetings and a question
    By Jono in forum New Member Introductions
    Last Post: 04-04-2017, 12:06 PM
  2. VFD Question
    By Chaz in forum Motor Drivers & Controllers
    Last Post: 14-01-2017, 08:41 PM
  3. PSU question
    By iforeman in forum General Electronics
    Last Post: 23-11-2016, 10:56 PM
  4. question ...
    By Wobblybootie in forum General Discussion
    Last Post: 04-01-2010, 12:04 AM
  5. A question
    By bodgeitandscarper in forum Gantry/Router Machines & Building
    Last Post: 02-12-2009, 08:30 AM
