    It seem that information was unworthy of a response, so good luck with your panel.
  2. The Following User Says Thank You to EddyCurrent For This Useful Post:
  3. #2
    I meant to reply but my original eBay order doesn't have the dimensions and I keep forgetting to measure it...
    However, from memory, I think it's 500x400x200. In that, I have a CSMIO motion controller, four stepper drivers, safety relay, stepper PSU, psu relay. On the inside of the door I have a 24V and a 5+12V PSU. Two 12V fans on one side blowing air in, across the stepper driver heatsink. It fits, but there isn't really any space spare and wiring is more difficult if space is tight. If I were doing it again, I would go a little bigger. Beat easy, if you have the bits, is to lay them out on the bench and see how much space they take up, allowing for things like internal cable guides.
    Don't know if that helps as it all depends on exactly what you are going to be installing.
  4. The Following User Says Thank You to Neale For This Useful Post:
  5. #3
    Good tip to get al the bits and make a layout.
    But at least 500x400.
    Ok...
    Thanks guys.
  6. #4
    No i am sorry Eddy... just busy at work..
    I have found this forum very informative with lots of nice people willing to share good information.
    Thanks for all the good information.
    Grtz Bert.
  7. #5
    Lives in East Lothian, United Kingdom. Last Activity: 9 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,987. Received thanks 373 times, giving thanks to others 9 times.
    Far bigger than what you think you'll need!
    My smallest control box is the one used on my little digitiser (photos can be found at https://www.flickr.com/photos/mc_mtb...57646048305954). IIRC it's a 400x500x150, as I happened to have that size lying around. With that setup, I certainly wouldn't go any smaller, and if I was using separate stepper drivers/controller, I would of wanted something a bit bigger.
  8. #6
    Ok thx for the pictures.
    500x400 doesnt look that big any more...
    I will look at my options when i have the parts.
    Grtz Bert
  1. Controller Cabinet
    By cropwell in forum Workshop & Equipment
    Last Post: 19-12-2015, 02:23 PM
  2. Tool magazine access and the Siemens CNC Sinumerik controls
    By cossiegaz in forum Siemens (Sinumerik)
    Last Post: 05-11-2015, 10:14 PM
  3. FOR SALE: XYZ PRO 3000 with Prototrak MX2 controls
    By FarrerDesign in forum Items For Sale
    Last Post: 17-06-2013, 11:47 AM
  4. DRives and Controls 2012
    By georgetheforge in forum General Electronics
    Last Post: 02-04-2012, 02:51 PM
  5. Stepper shaft size and pulley bore size problem
