Page 2 of 2 FirstFirst 12
    Thanks,
    tool-height setting during a tool change, which is a bit of a bugger..
    THAT was the issue - was going to try that on the mill as it worked great on my mini-mill but that only had a UC100 controller on it. In the end i gave up and locked-out all the auto-set buttons on the screen-set for safety.
    It seems my idea will be ok as having the M6 macro move the Z axis works fine so having it also move the knee should be ok too.
    Thanks for that link, very interesting reading.
    As it seems to do with auto tool length and as i am not using that, it also seems to back up my hopes that my new ideas will actually function well for me.
    I'm not sure if it's to do with TLO directly, or some of the stuff that gets done at the same time. I don't use TLO as I have the usual ER20 collet on my spindle, so no repeatable tool settings. I have modified some of the tool height setting macros that are often mentioned to work with my setup and controller (so it uses the CSMIO M31-type probing, for example) and I have the usual tool height, initial tool height for multi-tool operations, and second-tool setting macros. These all work fine with the m6 macros now, including various combinations of G28 and manual jogging while tool-changing. Seems pretty solid once I upgraded to the older Mach3!
    I'm also pretty confident that the probing and movement stuff works fine in X and Y as well, as I threw together some macros for X and Y probing while setting up the machine and they seemed OK. Not sure that I ever used them during an M6 sequence, though - that seems pretty unlikely. But at least they do work when needed, with the older Mach3 version.
    Still tempted every time someone mentions UC300ETH, though - seems to do pretty well everything the CSMIO/IP-M does, and in a supported package. If you buy an expensive BOB to go with it, anyway...
    That looks ok, I'm a bit confused about the LPT part - if its ethernet, how can it be LPT??
    Anyways, the price difference will drop when you add in the cost of all the connectors/adaptors to get from the header sockets to real-world cable connectors etc. Still looks a good board though.
    UC300ETH + UB1 + UCCNC license = $380 US.
    Closer feature wise to the IP-S than the IP-M.
    And the macros always work.
    The LPT is just the way the pins are configured. They match a parallel port pinout, so that just about any breakout board will plug right into it.
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
    It talks ethernet to the PC, but instead of direct outputs like the CSMIO range, it has a set of 5 "parallel port" style output connectors. In fact, they are standard PC board headers and each needs to be connected (simply) to a terminal strip (or cheap BOB as the connectors carry the same signals as a parallel port) to give access to the connections or (much better) to a custom BOB which provides opto-isolation plus the potential for 24V signalling. There is a fancy BOB specifically designed to go with it that provides opto-isolated access to all its IO ports. Not sure if it can also handle differential signalling for connection to stepper drivers. The combination isn't cheap - the BOB costs as much as the controller board, I think, but the combination plus UCCNC is competitive with the IP-M if you also add in Mach3.
    (edit - Gerry was quicker off the mark! UB1 - that's the board I was thinking of)
